Like Tree352Likes
NOVAROSSI Engine thread....
Old 07-29-2019 | 11:01 PM
  #10381
mustangkillaz's Avatar
Default New on road .21
Looking at another wc35 and mephisto. Anyone have actual experience with both? Looking to hear what differences if any were noted.
mustangkillaz is offline
Old 07-31-2019 | 03:27 AM
  #10382
roblupo's Avatar
The mephesto is a good engine but its not going to knock your socks off with power. Its a four port engine with a small crank compared to say a Mito 4. For that reason it is smoother on the bottom and on looser tracks it will be a good choice. The stock pipe suggested for it helps the engine get up to speed and with the DLC coated crank gives it high revs for longer straights with goo gas mileage. Only issue is its softer on the bottom but with some testing and some diff headers for diff conditions it can be good. I ran it with a 41031 header and the 2135 pipe but does not have that great of gas mileage. Also don't be afraid to run it with a 7-7.5 venturi to open it up.
For the price I like the Mito line of engines and the Rolling. Far better choices with power without having to have a lot of extras to make it go fast out the box.
roblupo is offline
Old 07-31-2019 | 08:36 AM
  #10383
This is the offroad section, might get better answers in the onroad section.
DLC doesn't do anything for top speed, performance differences comes from other things.
Pedro Jesus likes this.
NitroVein is offline
Old 07-31-2019 | 09:48 AM
  #10384
DLC is used for 2 reasons:
1) surface hardening
2) low friction surface to deal with the issue where lubrication stops working.
Lubrication is an issue with high rpm engines like the onroad engines. Lubrication has a speed limint to where it works. Going beyond lts say 45.000rpm with onroad engines there is a short moment of a bad lubrication, the low friction DLC surface will take care. All depends the qualuity of the used oil.....
Basically only the crankpin is most needed to have the DLC, that the whole crankshaft is done is just the process.
Roelof is offline
Old 07-31-2019 | 04:46 PM
  #10385
There is other ways to reduce the friction as well, some is used before they apply the DLC or it would turn in to a file.
But the hardness and low coefficient of friction does help if the oil or additives isn't there. I guess one reason why it has become more popular is all the full synthetic fuels for racing.
Piston pin can also benefit from it, but I don't think there is any engines anymore that run that.
Old 08-03-2019 | 09:07 AM
  #10386
Paloma @$169 vs Bonito @ $189
Hello, I am looking for a new engine for my Inferno GT2, and I am wondering if there is a huge difference between the two motors.
The specs read the same for both, and I am curious why the $20 difference between the two... what makes the Bonito superior?
Mr. Nice Guy is offline
Old 08-04-2019 | 02:00 AM
  #10387
am
Try rhe angeld 41001 or 41005 headers. Gives you more power. The 180 curved ones smoothend out engies to much.
am is offline
Old 08-10-2019 | 12:53 PM
  #10388
srt4johnny's Avatar
What header would you guys recommend for the Nova Rolling 7 port in a truggy with the 9901? Shorter tight track running Losi 4 shoes dynamite aluminum with 2 gold 2 green springs. Thanks
srt4johnny is offline
Old 08-10-2019 | 07:23 PM
  #10389
RCHammerr's Avatar
I have two Nova Engines .21, One needs to be repinched and has a new piston shaft the other is for parts, if anyone is interested ?.
RCHammerr is offline
Old 08-11-2019 | 01:10 AM
  #10390
Old 08-11-2019 | 02:44 AM
  #10391
srt4johnny's Avatar
Originally Posted by NitroVein
What about 41032 or 41033 vs the 41001?
Old 08-11-2019 | 07:21 AM
  #10392
They will all work, but if you're going to run a truggy on a short track I would go for one of the "square" instead of curved, and a longer will give you more bottom end.
Manifoldsi for 3,5/4,66cc Off-Road Engines - NOVA | Novarossi World - NOVAROSSI WORLD
Old 08-11-2019 | 09:42 AM
  #10393
The square 41032 will give the most top end of any of those manifolds - it’s the shortest and conical. If you care about fuel mileage, you’ll probably want to opt for a cylindrical header of moderate length. These manifolds make less power, which in turn consumes less fuel.
As has been mentioned by Neal and others in the past - the manifold has more influence on an engine’s behavior than the pipe ever will.
I wish I could get ahold of a shorter conical manifold than the 41032 for my 8T 3.0 with mod P5XLT engine. It could use more top end. I’m in the process of managing the clutch and adjusting differential oil viscosities in the meantime.
RCTecher12 is offline
Old 08-11-2019 | 01:17 PM
  #10394
You think?
I see the manifold more as a fine tune on the exhaust.
Roelof is offline
Old 08-11-2019 | 02:38 PM
  #10395
You think?
A fine tune? LOL. The manifold is the heart of the engine only next to the port size, shape, and timing. Hardly part of the “fine tuning”. That’s what the pipe really is because most 1/8 pipes are very near the same size and volume. Internal shapes and lengths can alter the wave timing, but the biggest factor is the overall length of the system.
