Like Tree352Likes
NOVAROSSI Engine thread....
Old 03-30-2016 | 07:41 AM
  #8881
fizzy's Avatar
Ahh problem solved, thanks
fizzy is offline
Old 03-30-2016 | 10:52 AM
  #8882
So I haven't raced nitro in a couple of years and am looking for a new engine. My old engine, which I still have, is a 21-4c. Absolutely love the engine. I think the logical choice would be a 21-4 Keep Off, but I also see a-main has a 21-7 Vir-Tus on sale. Has anyone had any experience with the vir-tus?
R.M.S is offline
Old 03-30-2016 | 12:48 PM
  #8883
TruggyDude91's Avatar
You can get the Vir-tus much cheaper on NovarossiDirect.com.
The Virtus is more of a truggy engine, I think the 21-4 keep off or MITO 4 would be a smoother buggy engine. But to each his own, come people like blistering power in buggy.
TruggyDude91 is offline
Old 04-03-2016 | 08:26 PM
  #8884
HaulinBass's Avatar
having a little fun trying to dial in the baseline tune, this old buggy doesnt react to throttle or brake inputs in the air anywhere close to my ae buggy but im not going to bash my race car.
nv21b square stroke/werks 086
https://youtu.be/gkvpHMOVxO0
HaulinBass is offline
Old 04-03-2016 | 09:01 PM
  #8885
Default 9853/41001 vs the rest
Does anyone have any experience with the 9853/41001 setup? Just wondering how the performance compares to 9853/41021 or even 9901/41021. Also, what is the 9901/41001 setup like in compared the 9853/41001
TLR 8 4.0 is offline
Old 04-04-2016 | 10:18 AM
  #8886
SEF's Avatar
SEF
For truck and in my mito 7, 9853/41001 is my favorite setup. Great power down low and generally good power all around with good mileage. I can pit at 10 minutes while still having plenty of rip.
SEF is offline
Old 04-04-2016 | 01:53 PM
  #8887
bash bros's Avatar
9853/41001 = balls to the wall, plenty of all around power doesn't really sacrifice top end either
9853/41021 = smoother low end, probably a little better on a dusty low bite surface.
Ran both of these combos in truggy last year with the elite 5 and p5xlt, for buggy 9901 might work a little bit better but it probably depends which engine you plan on using also.
bash bros is offline
Old 04-05-2016 | 07:38 PM
  #8888
cczjordan's Avatar
My btta engine has a problem with low end, previously it run good but suddenly it dont have low end power n will surge. Some guruS told me the main bearing is tossed. Any idea?
cczjordan is offline
Old 04-05-2016 | 11:51 PM
  #8889
[QUOTE=cczjordan;14479233]My btta engine has a problem with low end, previously it run good but suddenly it dont have low end power n will surge. Some guruS told me the main bearing is tossed. Any idea?[/QUOTE
To check to see if main bearing is toast, run the engine on the starter box. If you hear a ringing noise, like metal on metal contact that goes away when you place your hand on top on the cooling head, then the main bearing will need replacement.
Also, check to see if all your fuel lines and fuel clunk are good and clear, check and replace gaskets and springs, then retune and see if problem persists
Old 04-06-2016 | 02:26 AM
  #8890
cczjordan's Avatar
[QUOTE=TLR 8 4.0;14479503]
Gaskets replaced, retuned done but no clinging sound. Just sudden lost of bottom power n will surge after then same problem happened again.
Old 04-06-2016 | 05:42 PM
  #8891
What's you guys take on factory break in motors done by Factory ? What's the best procedure to use to get motor race ready once installed in the car ?
Ofna2005 is offline
Old 04-06-2016 | 05:59 PM
  #8892
1/8 IC Fan's Avatar
Try over here:
http://www.rctech.net/forum/offroad-...eak-bible.html
1/8 IC Fan is offline
Old 04-07-2016 | 12:29 PM
  #8893
Most of the "broken-in" or "pre-run" engines that manufacturers offer are still not completely broken in engines out of the box. Usually these engines will come with a piece of paper inside the box that says you need to run X amount of cc's of fuel through the engine being easy on the throttle then you can put a race tune on it. If it were me, I would just buy a normal engine, send it to a reputable engine service, and have them break it in. Then all you have to do is throw it on the track and adjust the tune for your area. No additional break in needed. But I also prefer to break in my engines myself. I use the "Bess Method" and have never had any problems with my engines using this method.
Old 04-07-2016 | 01:39 PM
  #8894
Roelof's Avatar
Only in an heated oil bath for me.
http://www.rctech.net/forum/onroad-n...h-machine.html
Roelof is offline
Old 04-07-2016 | 04:38 PM
  #8895
kaptain crash's Avatar
The engine MASTER seems to have lots of spare time. Your knowledge with engines is just Crazy!
kaptain crash is offline
