NOVAROSSI Engine thread....
#8716
6.0 Nitromizer insert. Tried the Nova stock 6.0 insert but lost low end drivability and about a minute of run time with it. Didn't see a difference in top end. But that was when the motor only had about a gallon on it.... she has about 5-6 on it now. Still has great compression but will be due for repinch/ rebuild by June/July time frame.
Also been thinking of ditching the 2096 and using the 9883 with 21 header. Herd to many good things about that pipe.
You'll also get told to run an 8mm insert...it'll get 5 minutes of runtime too, haha.
That said - I'd try at least a 6.5 or 7.0, and see what kind of mileage you can get.
I haven't tried it - but a buddy told me if I ever run a P5 based motor to buy and run this crank:
http://novarossidirect.com/15006_p_2167.html
#8717
N21-3T crankshaft?
If you want milage then go your way. But kep in mind you will loose lots of power.
#8718
That 9886 pipe does magical things - 2 chamber blah blah blah.
#8719
I ran the 7mm insert and 2096/021 combo for a while in my truggy and it completely killed the top end. Ended up going to 9853/001 with the 8mm insert and it was a completely different engine.
If all you want to do is swap headers maybe try the 41001, 41032, or 41019. The 41021 is smooth, but a lot more tame than the square headers.
#8720
Not really wanting to get inside the motor.... That's why my original question was just about headers only... If I wanted to break the motor down, I would just get a new one and be done with it. Too much headaches and too many things to go wrong when frankenstiening mills. Im pretty sure engine manufacturers do their home work on their motors. Ill leave that to them and reap the benefits...
Does a ceramic bearing make so much difference to standard steel balls?
Does a silicone filled + tungsten balanced crank make much difference?
#8722
Same thing with the 41032, its a conical version of the short 41019 square header. Makes a lot of power especially with a 9853 or 9886 and probably best for a high bite track or in truggy.
#8723
I run the Mito 4, 41031 conical with 2096, does not lack low or high end, as compared alongside other race engines. I think it is an upgrade over the 41021 on which it is based and worth running...
#8724
The square manifolds make quite a bit more power and RPM then do the curved manifolds...41032 smashes the 41033 just the same as a 41019 smashes a 41021........... 9853/9886 will substantially outperform the 2096 , and there will be no issue with run time, in fact the 9886 combo may even get better runtime considering your capped out looking for more top.... These 2 chamber pipes used to be the go to pipe till EFFRA forced a 3 chamber rule 10 years ago.........the rule was enacted because EFFRA wanted to slow the engines down and make every quieter.. Bad news is the 3 chamber pipes reduce power more effectively then they reduce noise......so basically racers everywhere are now running pipes thats primary purpose is to slow the engines down and reduce noise instead of pipes developed for performance and efficiency........ And no you don't increase mileage in a engine by choking off its exhaust so throw that concept out the window......
#8725
#8726
#8730
352Likes
