Viper RC -
#9812
#9813
I know this has been addressed before but I've got a Hakko 888 soldering station with a 5.2mm tip and I'm trying to unsolder the stock power wires so I can lay them down a bit more.
I'm not even really putting a dent in the stock solder at 675deg for 10sec with a freshly tinned clean tip.
I'm kind of worried I'm gonna do some dmg if I put much more heat into it. Is there some black magic to get them unsoldered or do I just blast it with heat and pray for the best?
#9814
I was putting some solder on the tip but didn't try feeding a little more to help removal.
#9817
Ok to give a complete breakdown of my setup and hopefully what can alleviate temps:
4wd buggy with 6.5t motor with 0 degree can timing
Vtx10BER with I assume no boost/timing, eg I have never entered the "power" part of the settings
Punch 65%
In misc controls forward power set to 90%
Throttle Pwm 12000
I can coming off the track with the motor just over 200 degree's (measured inside the motor through a hole.
I will try adding a couple of fans one to push air on and one to pull it away, but what else can I try on the esc!?
Also, I assume as std all the advanced timing stuff is off/set to minimum already right? I've never used that menu!
Punch 65%
Throttle Pwm 12000
#9818
DaveG - Make sure you are in Race Blinky mode (Misc Tab - Mode). Motor heat will generally come from gearing, so how would that compare I didn't see it listed. Internally, motors can quite easily measure 200*, externally they should not.
Toyman - Simple answer yes.
gawith - area of 120amp
Barge - get the spot you are trying to solder hot with the tip first, then feed in some solder to get it all flowing.
#9819
Question..
I have a E 3.0, Tekin Gen1 2050 buggy motor with a Vtx8.
Sometimes when I turn it on (randomly) it almost seems as if its in limp mode. Now if I turn off my transmitter and unplug my battery it will most likely reset.
Sometimes I have to do this a few times for it to work.
There is another racer at the track that experiences the same problem as well.
I've switched to viper from tekin and look forward to using it more!
#9820
Question..
#9821
I have steering yes, but I also have a limited amount of throttle.
Best way I can describe it would be as if your real car had a misfire while giving throttle.
It acts as if a cylinder is misfiring lol. I know that's an odd way to describe it.
4Likes
