Tamiya TRF415
#6001
Dawg, you might try here:
http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
or call Steve at Speedtech, his site is down right now for rebuild and inventory. his phone # is 909-869-9443
#6004
So now the 415 has been around for a while... wat are some of the good aftermarket parts to get for this car to eliminate some of tamiya's in-built flaws?
I'm trying out some rpm ball ends to see if they last longer than the stock ones (with less play).
Anyone discovered some good quality bearings to eliminate the failure prob of the small 950's in the lw suspension?
#6005
Originally posted by BlackKat
Hey,
Can someone explain the C1 & C2 thing to me? Like which one on which side does what?
Hey,
#6006
Originally posted by Arun
IThe reason that the pro-squat helps our car on carpet with foams is because it frees the car up going in and allows the car to be smooth coming out and on power. This way, the car is not scrubbing speed and is rotating extremely well (not "too stuck").
How do you have the roll center set up front? Also, what rear toe-in are you running?
Sorry about all the questions, but I have yet to put my car down on the track and trying to do all the bench racing I can now to use this information when I start to dial the car in in January.
I dont know if any of guys are from DC/MD/VA area, but THE TRACK in Gaithersburg, MD is having a race on January 29th.
#6007
Hey,
Hey,
#6009
[QUOTE]Originally posted by rcfiend
Hope you had a Merry Christmas as well. So, I take it that you picked up a 415. Are you thinking about TCS?
Posted By Neil Rabara[ Keith, I'm not sure but I think the new World Champion Parts Kit comes with it. I saw this on eBay.
http://cgi.ebay.com/ws/eBayISAPI.dl...581509&rd=1/QUOTE]
Whatup Neil. Hey the worlds kit only comes with the rear blocks not the front bridge blocks. The rear blocks dont have the bridge to clear the front belt.
Hope you and the family had a Merry Xmas.
Keith
Keith
#6010
I've been thinking about getting a 415 but thought the setup sheet could be cleaned up a bit for us non-japanese speaking drivers.
Check it out.
http://209.151.201.222/smash/trf415lw.pdf
Check it out.
#6011
Keith
#6012
Yes I picked up a 415 and a EV04, trying to decide which one I'm going to keep. As it stands the 415 has a slight edge.
Keith
Keith
#6013
Originally posted by Apex
So did you see in a difference in lap times by adding pro-squat? Or did this just help make the car feel more driveable?
Rear toe-1.5 degrees (al. 1deg upright with 1C-1D blocks)
My front roll centers are...well...interesting.
I have a lowered ballstud in the upper-outer position (foam tire clearance). I have a 1mm shim under the upper-inner ballstud.
On the bottom, I have flipped the roll center blocks, ground the area where the screw normally protrudes flat as I described above, and placed 4mm of shims underneath. This, in effect, lowers the pivot point by 1mm, giving the car more steering. My front-rear block is a 1A (which, when flipped, becomes a bridge), and my front-front block is a 1B.
This 1A-1B front combo also gives .5deg of in-board toe out, helping the car react quicker into and out of a corner.
This picture should clear up any confusion.
3Likes
