Old 12-27-2004, 11:41 AM   #5971
ngo8's Avatar
Send a message via ICQ to ngo8
I think i am going have to try this soft oil set up thing that everyone is talking about cause the basic carpet set ups that works on every other car doesnt work on this car
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 12-27-2004, 11:49 AM   #5972
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Nice to see people are trying a soft chassis set-up. I've been runing the Tamiya springs, Purple Fr / Gray rears. (posted my set-up a number of pages back).
My car worked very well with this set-up. These are Tamiya's heaviest springs, 20-22.7lb range. with 50wt oil.
Remeber each person is different and prefers a different set-up. No one set-up works for everyone. I like a lot of chassis roll in my TC. Raul runnings his TC's stiff, almost like a pan car. Both cars get around well, its just a different driving style.
My style is fast. Raul uses the entire track
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 12-27-2004, 11:53 AM   #5973
softer oil seems to work with the turn in speed and sems to produce a bit more grip?
the tyres we use are quite low grip even on carpet so we need the softer springs.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 12-27-2004, 12:22 PM   #5974
Send a message via AIM to JackinTampa
I made a background for my car.
JackinTampa is offline   Reply With Quote
Old 12-27-2004, 12:29 PM   #5975
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
Originally posted by Carl Giordano
[B]Nice to see people are trying a soft chassis set-up. I've been runing the Tamiya springs, Purple Fr / Gray rears. (posted my set-up a number of pages back).
as i remember, at last years Novak race, i ran the purple/grey springs on my Evo III, rubber tires. 2-hole pistons, with 45 wt oil. i am probably gonna start about there with the 415 and Evo IV this time.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 12-27-2004, 02:27 PM   #5976
koabich's Avatar
Send a message via Yahoo to koabich
Originally posted by trf racer
as i use rubber's on carpet so i stick with the tamiya springs.
on the back i use the yellow springs on the back with n anti roll bar and the shocks are mounted on the 2nd hole in[old shock tower].
on the front i have no anti roll bar with blue springs.
ive got 35 weight shock oil on the front with 30 on the back.
everything else is kit settings.
i still have a tad too much steering.
but these are quite soft.
as other ppl said.
Well if you are still having too much steering there are several things to try. Since you don't mention at what point in the turn you are getting too much steering, I am going to assume that it's too much initial turn in:
-Add a thick sway bar to the front (I would try this first)
-Add a sway bar to the front and remove the rear
-Stiffen up the rear springs
-Stand up the front shocks a little
-Lay down the rear shocks
-Try stand up the front shocks
These are all the things i would do to correct the problem in the order I would do them. There are many more things that would lessen the steering but I would try these first as they are easiest and one or all will more than likely correct the problem.
koabich is offline   Reply With Quote
Old 12-27-2004, 02:35 PM   #5977
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Randy Caster
Does anyone know if the bulkheads from the MS mount any different than the stock 415? I might just buy a 415 and a new MS and put the MS bulkheads and goodies on the stock 415 for a carpet car that will be rarely used, lol
Randy... PM me... I can just get the MS Bulkheads if you just want them ... If not thats cool... I just ordered them last week should pick them up today
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 12-27-2004, 04:36 PM   #5978
JimmyMac's Avatar
Yeah we've met ARUN. Kumpol told me about the softer setup. But I've only had 4 battery packs through this car on carpet (2nd qualifier, 3rd qualifier, main, practice after main. I missed the 1st Q setting up the car hehe). Ran great from the start. I'll give the softer setup a try this weekend since I have 2 sets of shocks. I'll see which one feels better and produces better lap times. Our track is not as small as yours.. nor as technical. It's more of a HorsePower track like the Snowbirds. So I'd be interested in seeing how the softer setup works. I'll post my findings Saturday night.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 12-27-2004, 04:45 PM   #5979
TryHard's Avatar
Whoops double post. main one below.
| THard.co.uk | Xray | MuchMore |
Old 12-27-2004, 04:46 PM   #5980
TryHard's Avatar
Koabich, Surely that should be
-stiffen up the front springs
as the rears wouldn't have an affect if it's on turn-in... ie weight is being transfered forwards, therefore front springs are being compressed, not the rears. You could try running stiffer shock oil in the rear though (or both ends for that matter)... that would have an affect, by reducing the rate the weight is transfered.
Ed
Old 12-27-2004, 08:15 PM   #5981
Randy Caster's Avatar
Trader Rating: 46 (100%+)
-Dave
YGPM
Old 12-28-2004, 12:02 AM   #5982
Are you coming to the carpet race in two weeks?
James Nguyen is offline   Reply With Quote
Old 12-28-2004, 12:03 AM   #5983
This is gonna sound bad, but there's a carpet race in 2 weeks?
Old 12-28-2004, 12:04 AM   #5984
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Northern Cali is where its at!!!
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 12-28-2004, 12:16 AM   #5985
Yeah. 2005 Northwest Carpet Champs
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
