Tamiya TRF415
#6751
I just got a TRF415 MS, and I was wondering if anyone could share a good carpet/foam tire set-up? I have always ran a XXX-S, and I thought that I would give the 415 a try. I run on a tight indoor carpet track. What exactly does the one-way on the center shaft do that the front one-way doesn't already do?
#6752
battery strap
hello all..
wondering if there is a way to install a permanent battery plate holder??
I noticed the winning 2004TCS Japan car has a carbon fibre plate holding the battery in ...
is that a tamiya part ?? if so can someone pls tell what/how i can use to hold the batteries down instead of the strapping tape ...
thanx alot .
thanx alot .
#6753
You could use the X-Ray 6 cell battery strap and posts
#6754
I think that was the stick pack chassis kit on that car. Not sure though, but I thought they had a battery holddown strap for that special chassis. I just ordered the XRay 6cell strap. So I'm gonna try that this week.
#6755
John, goodluck with your new venture. I look forward to your stuff.
#6756
Re: battery strap
Originally posted by hapiya
hello all..
thanx alot .
hello all..
thanx alot .
#6758
Re: Re: battery strap
Originally posted by linger
At the worlds, we were required to run stick packs; so we all obtained the 415 stick pack chassis, which comes with the carbon fiber battery hold down plate. It won't work easily with the regular chassis since there are no mounting holes.
ooh i see ,... is it possible to get the 415 stick pack chassis as a hop up ??
one of the guys i know has installed the xray strap down on to the 415 ...however i'm afraid it'll tweak the chassis over time with the screw down strap .. and lack of proper drilled/prepped holes ...
thanx alot ..
#6760
hapiya...If you are unsure of drilling the chassis take it to a machine shop and get them to do it. The X-Ray strap screws down one end but pivots on a ball/cup type deal. I dont think you would have any tweaking problems. Grab someone spare or broken X-Ray chassis and use it as a hole template
#6761
R/C Tech Elite Member
#6764
so can i take a count...who is running on spool and who on one way....
