Old 03-25-2006, 11:53 PM   #13501
Stein Tumert's Avatar
Default TA05 front pully
Originally Posted by tcmerf
I went out and got the pulleys for the TA-05. How are you guys mounting them. The front pulley does not share the same mounting holes. Should have known it was to simple! Factory guys always have unobtanium! I guys thats why they are factory.
Which front pully did you get?
The TA05 (front) diff pully or the TA05 one-way front pully(#53867)?
Stein
Stein Tumert is offline   Reply With Quote
Old 03-25-2006, 11:59 PM   #13502
Stein
I got the one way pulley but it actually looks identical. the only difference is the center hole is much bigger.
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 03-26-2006, 12:19 AM   #13503
Strike that last post. It does not fit my Speedtech spool because it uses 3mm screws to mount. The Tamiya one way seems to work. Guess i need to get a Tamiya spool. Today was the first time i ever used a spool and it seemed a lot easier to drive. The only thing i am worried about is that the spool is so much harder on the drive train. Today was a lot of fun at Tamiya, the place was packed. There ws always someone on the track and sometimes as many as 7 or 8 cars at once.
FT B44 - FT J82
Old 03-26-2006, 09:36 AM   #13504
John Tag's Avatar
Trader Rating: 42 (100%+)
Anybody have any links to online shops that carry Tamyia 415 parts,I'm looking for part # 50985 and speedtech is out of stock and I wanted to order these before I go away for vacation tonight..
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 03-26-2006, 09:54 AM   #13505
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Arrow RC TRF414M F Parts - Hub Carrier #50985
Tamiya USA Online Store or Jason's Store
Hope this helps.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 03-26-2006, 12:14 PM   #13506
John Tag's Avatar
Just ordered from Tamiya online thanks.. Just hope they come in before weekend.. If anybody has a set they can sell and ship to me before friday PM me and I'll take those too just in case others dont show ontime...
Part # 50985
Old 03-26-2006, 12:48 PM   #13507
Ok i got the ta05 pulleys installed and here is what i have found. The diff pulley seems to be a direct fit but the one way is a bit more of a clallenge. It is wider so it will not fit between the bulkhead without narrowing it up. it is probably only a couple of mm but it is still enough to cause issues. I can see where belt tension may be an issue as well as i have them 4 notches from full loose on some old belts and they still could be looser.
FT B44 - FT J82
Old 03-26-2006, 12:52 PM   #13508
Patriiick's Avatar
some ppl use xray belts with the Ta05 setup, hope it helps..
Patriiick is offline   Reply With Quote
Old 03-26-2006, 01:16 PM   #13509
Thanks. Its time for new belts anyway. Were there some aftermarket ones out there somewhere to?
FT B44 - FT J82
Old 03-26-2006, 06:44 PM   #13510
JimmyMac's Avatar
Hey Tag.. Ron Z has those parts... I gave him all my spare "old" suspension stuff when I sold him the car.... Tower Hobbies doesn't have them as that part number.. but they do have the "racing" set. But it costs alot more. Just type in TA04 under the search option. http://www2.towerhobbies.com/cgi-bin...?&I=LXZR77&P=7
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 03-26-2006, 06:45 PM   #13511
JimmyMac's Avatar
Tag... I'm also surprised you didn't ask me first... lol
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 03-26-2006, 06:50 PM   #13512
dodo's Avatar
Send a message via Yahoo to dodo
any tips on how to file down the center part of the pulley so that we can fit the one way? anyone? thanks
dodo is offline   Reply With Quote
Old 03-26-2006, 07:07 PM   #13513
John Tag's Avatar
Thanks Jimmy..I like the added blue..heck I got some good tires while I was there too...
Old 03-26-2006, 07:42 PM   #13514
The 05 pulley is slightly wider, but i found if you loosen off all the bulkhead screws including the shock tower screws and install the 1 way with the 05 pulley, when you tighten everything back up it will fit ok. although there is no sideways movement in the pulley, prob not the best for efficiency but it will run fine.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 03-26-2006, 08:03 PM   #13515
dodo's Avatar
thanks, but i believe it's important to have the efficiency. No doubt it will roll but if it's roll inefficiently maybe it's better to leave it unchanged. Anyway, for those who tried, any significant improvement from the stock drivetrain?
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
