Old 01-03-2005, 04:52 PM   #6151
linger's Avatar
Originally posted by TryHard
actually ayone have the part number for the thrust bearings? I think mine need re-placing, the diff feels real gritty, even with new balls in.
Ed
Thrust bearing part number is TAM9805670
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 01-03-2005, 05:22 PM   #6152
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Originally posted by Randy Caster
If you do make it, drop by my pit, most the people there should be able to point me out.
Will do.
Racing4Evo is offline   Reply With Quote
Old 01-03-2005, 05:36 PM   #6153
anyone know the part number or a shop that carries the diff screw used in the 415? i can only seem to find the 25mm one not the 30mm used in the new diffs
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 01-03-2005, 05:47 PM   #6154
9805939 2x30mm Cap Screw http://www.tamiyausa.com/pdf/58320.pdf
Galifrey is offline   Reply With Quote
Old 01-03-2005, 10:43 PM   #6155
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by Racing4Evo
Will do.
BTW, are you running the 415 or MS?
Old 01-04-2005, 06:38 AM   #6156
Trader Rating: 45 (100%+)
Default Suspension blocks on MS kit
Can anyone confirm what suspension blocks come with the MS kit?
Thanks in advance...
Apex is offline   Reply With Quote
Old 01-04-2005, 09:44 AM   #6157
1x X Block
2x A Block
1x B Block
1x C Block
1x D Block
1x A Bridge
1x D Bridge
Old 01-04-2005, 10:03 AM   #6158
1x X Block
2x A Block
1x B Block
1x C Block
1x D Block
1x A Bridge
1x D Bridge
wot r the x 4?
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 01-04-2005, 10:24 AM   #6159
1 times, 2 times...
Old 01-04-2005, 10:32 AM   #6160
1 times, 2 times...
what that mean
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
Old 01-04-2005, 10:36 AM   #6161
s2
s2's Avatar
Originally posted by trf racer
what that mean
AYE!!!!
lol i kinda hope your joking, but just incase.......
there is 1 X Block
there are 2 A Blocks
there is 1 B Block
there is 1 C Block
there is 1 D Block
there is 1 A Bridge
there is 1 D Bridge
s2 is offline   Reply With Quote
Old 01-04-2005, 12:19 PM   #6162
Default MS Parts...
So these MS Parts don't come in the MS kit?
I think these suspension bridges are even narrower than the current available suspension bridges.
Old 01-04-2005, 12:22 PM   #6163
alan1467's Avatar
No those are extra
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 01-04-2005, 12:26 PM   #6164
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Apex: they do not come in the MS kit. I was hanging with Casey this past weekend and may make the 1/29 race at Mimi's.
All you need from that option package is the one-piece layshaft belt pulley. The other parts were designed specifically for a very large asphalt track. Not worth it on our carpet tracks on the east coast.
Also, you only need the one-piece layshaft belt pulley if your running a front diff or solid front axle on carpet. I just assembled a front diff gear, I've yet to try it. I keep going back to the dual one-ways vs. the solid front axle.
Then again, I'm not running the MS kit on carpet. Working with the older 415 chassis and arms.
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 01-04-2005, 12:37 PM   #6165
Thanks Carl!! I'm thinking about getting an MS and wanted to make sure about the suspension bridges since I want to do some asphalt racing this summer.
Have you had any problems with tweaking?
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
