Like Tree4Likes
Viper RC -
Old 03-22-2013 | 06:45 AM
  #7246
Wildcat1971's Avatar
Tech Prophet
I would use 5mm on an 8th scale for sure.
Wildcat1971 is offline
Old 03-22-2013 | 07:07 AM
  #7247
Integra's Avatar
Originally Posted by Genebaby
I'm looking to install some bullets inline between my VTX8 and the Tekin 1900 motor. What size bullets should I use for this? 4mm?
IMO Bullets = resistance = Not recommended
Integra is offline
Old 03-22-2013 | 07:21 AM
  #7248
godofcable's Avatar
sometimes you dont have a choice though. The tekin has tabs so you can directly solder, but some motors come with the wires exiting the case of the motor, and in the case of the VTX8 it has wires as well. no choice there but to use some method to connect the two.
godofcable is offline
Old 03-22-2013 | 07:53 AM
  #7249
With the copperhead R speed control can I up the voltage to 6v using my proguage in order to power my Savox SC-1256TG High Torque servo or should I keep it at the stock 4v?
boostem is offline
Old 03-22-2013 | 09:26 AM
  #7250
AndrewTom's Avatar
stock 4 volts?
i don't know much about the Copperhead ESC, but i know you can adjust the BEC voltage with the ProGuage on the VTX10 and 10R. you can set it even higher if you want to, up to 7volts.
AndrewTom is offline
Old 03-22-2013 | 09:37 AM
  #7251
I can adjust it but havent tried because i didnt want to mess anything up. The specs on the speed control say up to 6v
boostem is offline
Old 03-22-2013 | 09:49 AM
  #7252
Tech Prophet
6v is fine
Old 03-22-2013 | 01:19 PM
  #7253
Genebaby's Avatar
Thanks guys, my main reason is ease of use. I want to be able to separate the ESC and motor when working on the car, rather than risking the solder connections going bad and redoing them over and over.
I guess the bigger the better? The ESC wires are under 3mm, I just measured them.
Genebaby is offline
Old 03-22-2013 | 02:00 PM
  #7254
Tech Prophet
5mm should be fine. no real need to go bigger.
Old 03-22-2013 | 02:07 PM
  #7255
Genebaby's Avatar
I have some spare 5.5mm bullets I no longer have a use for, I may use those. Initially I was thinking 4mm.
Genebaby is offline
Old 03-22-2013 | 02:14 PM
  #7256
Tech Prophet
I am sure the 5.5 will work fine. They will hold a little bit better then the 4mm also.
Old 03-22-2013 | 02:36 PM
  #7257
Genebaby's Avatar
Thanks, I'll use those.
Genebaby is offline
Old 03-23-2013 | 11:25 AM
  #7258
I just picked up a Dex210 and was thinking of getting the VTX10R+motor+programmer. I have yet to decide on which motor but have it narrowed down to either the 13.5 or 10.5. I'm just looking for any help on where I should start with gearing should i go with either. I have the stock spur and 26,24,22,20,18, and 16 tooth pinions.
jonu is offline
Old 03-23-2013 | 11:27 AM
  #7259
Tech Prophet
you dont need an R esc for 10.5 or 13.5. The vtx10 with PG is plenty.
Old 03-23-2013 | 11:59 AM
  #7260
AndrewTom's Avatar
I would get the 13.5, get out and practice with it.
you can always throw some boost to it if you want more power/speed.
if you do run boost, then the 10R is not a bad idea.
the R is not needed, but it is just nice to have the R if you don't want to worry about heat. they seem to hold value a little better too.
