Speed Passion Thread
#3121
Been running a LRP X11 7.5 in my SC10 with a GT2.0 LPF esc with 428MOD (no changes to programing).
With the LRP starting to show its age, I ordered a Com V3.0 7.5 today to replace it.
Is this still THE program (428MOD) to run or is there a better one?
I race at these tracks.
Red Clay
http://www.t3t4webservice.com/fzrc.html
Carpet
http://www.t3t4webservice.com/HMIRR.html
Red Clay
Carpet
#3122
Presume this is 2wd not 4wd? How are you gearing it? I want to put the LPF in my SC, though I might switch and try a different HW 120a.
MOmo
#3123
my brand new 2.1 pro stock esc went out after the 1st 5min run...Never got hot,ran perfect...all lights come on and fan..does not make beep sounds when I try to recalibrate but it does show the light blinking...Running a sp 10.5...Also tried another motor with no luck
...Never had an issue with speed passion,especially a brand new esc....
#3124
How do I put a Reventon S into blinky (stock0?) mode? I was using the LED programmer last night and I couldn't find a way to get it out of Mod0 mode.
Also, I have a 17.5 v3.0 that just stopped working. It was running fine for 5 min or so with good speed, then it would only move at nearly full throttle, then it stopped all together. I checked voltage and it was 8.0v (2S) and motor temperature wasn't even warm. I turned the ESC on/off with no change, tried a rolling start and no change. I swapped out the motor for a Turnigy 17.5 and ran for the rest of the night, even down to the 3.4v/cell cutoff without issue.
#3125
to change the firmware you need to hook it up to the computer. The box is for changing the settings with whatever firmware you load into it.
#3126
Totally dumb, but did you switch Sensor wire? Same sensor worked on the Turnigy?
MOmo
#3127
I am new to speed passion products but have heard a lot of good things about them, here is what i am looking for, I just purchased a B4.2 and am looking for a ESC and motor for it but really don't know which products speed passion has to offer that would be right for this buggy? Any info would be great.
#3128
Had to look! Haven't changed the gearing for over six months.
20/84
Was having a heat problem, a race buddy shared Maifield's setup from the ROAR race at Norcal 2011. The radio setting made the difference.
#3130
#3131
#3133
can someone explain how this hobbywing sct pro can be such a great 4wd sc or 8th scale esc with less amperage ratings than the reventon pro?
http://builtrc.com/hobbywing_xerun_esc_sct_black.aspx
Output: Continuous 120A, burst 760A;
http://www.amainhobbies.com/product_...sored-ESC-Blue
Current (Continuous/Burst): 140A/960A
4Likes
