Serpent 811E Buggy Thread >
Like Tree5Likes
Old 09-26-2012 | 08:21 PM
  #3046
On the Protek one can read "A 20 amp power supply (minimum) is recommended for efficient operation with 2S applications." Is it really important, I would rather not take a charger requiring a PS.
I didn't know about the Parallel charging Board, it looks like a good alternative.
Thanks for the info.
alex124 is offline
Old 09-27-2012 | 04:15 AM
  #3047
Oztiger's Avatar
Default Serpent Parts/Options
Any one tell me where I can order the new Composite Spur gear from?
Also the new Alloy Steering Servo arm. I am in Australia.
I ran the buggy for the first time on the week end. Super impressed. I ran 5.5.5 in the diffs with the standard set up. Had problems under power, the car wanted to crab sideways?? Found that odd?
Will be going to 7.5.3. for the next meeting.
Track was clay which blue grooves on the racing line after a few races.
Car flew the big jumps well and turns well under power as well as under brakes. I did brake heavily a couple of times before the end of the main straight which saw the car from somersault nasty distances. (no Damage). A lot of people commented positivley on the car .
Oztiger is offline
Old 09-27-2012 | 01:14 PM
  #3048
Doughboy305's Avatar
the new 2.0 full upgrade on Ebuggy
Doughboy305 is offline
Old 09-27-2012 | 03:15 PM
  #3049
bigjayjay1's Avatar
Can you keep us updated on the performance please. So thats the full 2.0 swap
bigjayjay1 is offline
Old 09-27-2012 | 03:27 PM
  #3050
Weather permiting ill be running it in about an hour
Old 09-27-2012 | 03:38 PM
  #3051
dirtydan's Avatar
Hey that's my 2.0 kit
dirtydan is offline
Old 09-27-2012 | 09:02 PM
  #3052
Default 2.0 upgrade
Ran the car at the local track track had very little traction but the new rear felt great definitely a must add to the car.
Old 09-28-2012 | 09:19 AM
  #3053
Originally Posted by RCmayor
A piece of cloth might work but it makes it fit even tighter. With a strap you take the whole door off so it is easier to get your fingers on both sides. Save yourself from a temporary bodge. :-) Ask anyone, these fit perfect and look the best.
you have pm!
one-nil is offline
Old 09-28-2012 | 09:41 AM
  #3054
rcq
First try 5 7 3 diff oils and thiner oils in rear shock. Now I am running 15wt with 8x1.4mm holes and green springs on the rear end. It help me .
rcq is offline
Old 10-01-2012 | 06:35 AM
  #3055
Big Will's Avatar
I'm running a Tekin 1900kv motor and the best possible possition I could install it in the sensor wire touchs the steering post. Is this normal?
Big Will is offline
Old 10-01-2012 | 06:44 AM
  #3056
BigRon's Avatar
Yes
BigRon is offline
Old 10-01-2012 | 08:13 AM
  #3057
Big Will's Avatar
Have any of you turned the front plate on the motor to get a better mounting possition? I'm having to use the smaller flat head screws to mount it to the motor mount. I would like to use the bigger 4mm screws instead. Is this possible?
Big Will is offline
Old 10-01-2012 | 08:54 AM
  #3058
weavty1's Avatar
Yes and yes.
weavty1 is offline
Old 10-01-2012 | 08:59 AM
  #3059
Big Will's Avatar
Thanks guys!
Big Will is offline
Old 10-01-2012 | 01:57 PM
  #3060
Just got in my 2.0 rear end update kit from dirtydan (thanks) and I am going to be running it with a shorty setup as well. Getting ready for the indoor season so I am pumped to try it out. I'll report back after I get it dialed in.
JoeC is offline
