Serpent 811E Buggy Thread
#2896
Thanks Jay! With your help via many PM's with setup info, hopefully it runs as nice as it looks.
Thanks so much Tekno! and I'm with you, I'm no fan of snakes, or spiders for that matter. But the idea popped in my head to keep up the snake theme while I was building.
#2897
#2908
On the speedo side, balance hole lines up perfectly. Motor side, I just barely have to push on the nub the cotter pin goes thru on the battery box and it lines up perfect. It has to do with the plastic and the mold they make the battery box with I suspect.
So far I am liking the Orion running gear, plenty fast and smooth power delivery.
I Just used the stock motor screws. I read on here (I think) many pages back about the tendency of the screws coming loose and the solution was blue loctite on the screws, so that is what I did before I even installed. So far, so good, no issues
#2909
Cool, the next run I think I will enlarge that hole a little from 3mm to 4mm-5mm or so. Thats a couple of reports of the hole missing a little. The good thing is it is just carbon, and if you need to drill it out a little you can. It shouldn't affect the strength. If you drill carbon use a piece of wood below it so the material wont tear out.
5Likes
....did you use corbon decal to cover that stuff? i have some that i might have to put to use, mud guards look good
