RC10B4.1 FT/WC
And no, they are not to long and do not stick out.
You will find these in the Airplane section at your LHS.
and to answer your question, yes most ppl prefer the ball diff, i dont know of anyone running a gear diff when given the option.
Con's: Takes a bit more maintenance like checking tightness and more frequent rebuilds. Gear diff is like the RONCO "set it then forget it" for longer intervals than the ball diff. Overall the performance gain out weighs the con's. Although there are those that say otherwise I'm sure.
So I've searched thru this thread, and I wanted clarification:
- Gearing for 17.5
w/ no timing - 78t Spur and gear to the moon (biggest pinion possible)
- Mod - Depends on timing, 81 spur and 20-26 pinion?
Local track runs a 17.5 no boost, blinky class. I just picked up a Peak 17.5 for now, till some other motors come in, but wanted to get some clarifying info answered.
I did a quick test, using an 81 Spur with a 30T pinion, and it didn't feel all that fast.
MOmo
- Gearing for 17.5
MOmo
know this has been asked already just too many pages to look through. How can i get more steering from my buggy i have 2 washers under ball stud on front shock tower. would removing these help if yes. one or both? run on hard pack dirt slight dust. running losi prescub 3 rib pink front tires
BTW, OCRC is an awesome clay track that can be loose without some Tire Sauce.
