RC10B4.1 FT/WC
Hi All,
Buggy noob so I'm going to ask the stupid question. I built my Worlds car and noticed there is alot of play in the wing. I have the shim under the wing on the mount so that the skinny end is forward but with that much play, the wing seels nearly useless. I know you want a little play so that it doesnt rip to shreds on the first rollover but mine is rediculously loose. Any input is appreciated.
KEvin
KEvin
I didn't even think about putting the washers up front,does it take two like the rears?
not bad but its something i get crap for from the k guys
sometimes i feel like, a sloppy car=a less notchy and easy car to drive fast.
i don't think you would notice a difference, i only felt a difference with my other 8mm car before i got the wc was when all arms, nose plate, u brace was carbon, i reacted smoother and made it a little easier to drive. Ik maybe I'm crazy but i prefer carbon parts mostly bc they don't wear. Ill be picking some up next time I'm at the track, after 5 raceways my front hubs and arms are worn
oh sorry i must not have read you post correctly about rtr or bushings i thought u thought the stock bearings where different then the ones u needed for the avid
Where he will feel the difference is when he is on low bite surfaces. Low bite you want as much flex / slop as you can get (within reason of course) because it will increase traction. I swear the worst mistake I have ever made was rebuilding my car with all new parts right before a big race.... made it feel totally different and much harder to drive.
I run on med to low bite black dirt, and its good. I was wondering if anyone has tried cvds lately.
im about to order some bearings off of avid so sence these are the same size as those bellcrank bearings you listed would these work also for the avid bell crank
http://www.avidrc.com/product/1/bear...-bearings.html
