RC10B4.1 FT/WC
Old 05-02-2012 | 12:51 PM
  #14251
idrummerboy13's Avatar
Originally Posted by easy e
the track was just built, trying to be the local fast guys..
I have tested every tire but not every compound every tire.. The main problem is I get better lap times every time because Im learning the track better. I really like the Sweep 10Droids but I only have them in silver (ss)
If there is no loam or loose anywhere on the track, is there ever a better compound then super soft.. (a/c indoor building never will be over 85*F)(I hope)
if you like sweep silvers try blues. They will last longer and have a little less bite unless they worked fine for you.
Also blue barcodes in v1 work when the silver sweeps do....
idk but the track was so dry everyones lap times were a second off and way much crashes... I added water to the clay and bam .7 tenths faster. I always like a damp track never found dry good unless its colder....
idrummerboy13 is offline
Old 05-02-2012 | 01:00 PM
  #14252
20 SMOKE's Avatar
Originally Posted by mekios
Has anybody in here tried using 3 hole drilled pistons?
i was running losi 3 hole but went back to the ae 2,i just liked the action of the 2 hole
20 SMOKE is offline
Old 05-02-2012 | 02:13 PM
  #14253
mekios's Avatar
Do you get more pack with that?
mekios is offline
Old 05-02-2012 | 02:14 PM
  #14254
lemonader83's Avatar
Originally Posted by Buckland
sounds like pinion mesh is too tight, when you go to tighten it down check to make sure the motor holes aren't stripped out. Sometimes if you crank the screws down the holes strip, the cans aren't steel like they were with brushed motors. I've had good luck putting a dab of blue lock tight on the motor screws and tightening them down pretty good, obviously don't go gorilla grip or you'll strip the motor, but you can get it nice and tight.
Thanks, I'll give it a try!
lemonader83 is offline
Old 05-02-2012 | 11:09 PM
  #14255
What's the favorite losi spring combo for wcrc?
danielXIII is offline
Old 05-02-2012 | 11:18 PM
  #14256
Red front Yellow rear.
Hpifanboi is offline
Old 05-03-2012 | 01:05 AM
  #14257
Good morning everybody,i have a problem with the +8.the previus sunday we race a new track.the problem is that the jumps are really high .Very few driver manage to jump good .Only the mid motor drivers did it so the win the race .One friend of mine had the normal b4.1 chassis and it was much better .It is high traction track .Any suggestions?it is about weight ballance?
you can find some videos on youtube if you search for this
2WD Buggy Final Α Part ΙI 29/4/2012
tuono46 is offline
Old 05-03-2012 | 04:22 AM
  #14258
elex300's Avatar
Originally Posted by Diliplifttruck
DILIP MATERIAL HANDLING EQUIPMENT manufactures and suppliers of huge range of Material Handling Equipments suitable for a wide variety of users.
MATERIAL HANDLING EQUIPMENTS, MANUFACTURERS | ELECTRIC BATTERY POWERED STACKER MANUFACTURERS | LIFT TABLE PALLET TRUCKS MANUFACTURERS
For More Details Visit :diliplifttruck.com/
elex300 is offline
Old 05-03-2012 | 04:58 AM
  #14259
t0p_sh0tta's Avatar
Finally tried a set of Losi springs last night, with the shorty pack and it was awesome. Fastest I've ever run. Felt much smoother than the Brown/Green AE combo.
t0p_sh0tta is offline
Old 05-03-2012 | 06:40 AM
  #14260
I believe it's orange front and yellow rear. The red/yellow were the first wave of springs since it's matched the losi 22 but since it's progressed.
If you look compare spring rates, the orange/yellow are considered 0.1 tighter and identify with the green/brown AE ones (although big bore springs do feel softer).
Kuya_Kimo is offline
Old 05-03-2012 | 07:26 AM
  #14261
rcfiend's Avatar
That's what I run at WCRC, orange/yellow. When the grip is really high I will run pinks in the rear. The pinks really help the rear to rotate.
Has anyone at WCRC tried the Advid springs yet?
rcfiend is offline
Old 05-03-2012 | 07:32 AM
  #14262
My LHS recieved a order and going to try them today.
Old 05-03-2012 | 07:56 AM
  #14263
I as well am running orange/yellow. I want to try the avid but a guy i was racing with last Sunday had just bought them and was really struggling getting them dialed it. He said the car was really bouncy and was trying all different combos. I am waiting until someone else gets the feel.
goin2drt is offline
Old 05-03-2012 | 08:04 AM
  #14264
Autocratic's Avatar
Originally Posted by Autocratic
Are Velvet BB shocks still a good investment or would it be better to wait for AE to release their BB?
Anyone? I've posted about three times now...
Autocratic is offline
Old 05-03-2012 | 08:26 AM
  #14265
I don't think so. Most are running the Losi BB setups. My best results have been so far are
Front. Losi Red springs with AE #2 piston AE 30wt oil
Rear. Losi Yellow springs with AE #2piston AE 27.5wt oil
Front toe slightly out. -1 camber all the way around. 23 ride height front and rear for smooth indoor clay track with AE's Steve Hartsons set.
24 ride height front and rear for bumpy dirt tracks.
