RC10B4.1 FT/WC
Old 04-09-2012 | 12:15 PM
  #13531
20 SMOKE's Avatar
here is what i did,i never used the angle the wing i always keep mine straight so i use the blue axle spacer driller larger and use one body pin.i can take a pic if some one want's
20 SMOKE is offline
Old 04-09-2012 | 03:07 PM
  #13532
idrummerboy13's Avatar
what shocks are on the b4.1 in the picture above?
asked a.e c.s about stock spring rubbing...."if spring is not centered on the cup they will rub."
well thanks...
idrummerboy13 is offline
Old 04-09-2012 | 03:17 PM
  #13533
Originally Posted by one4rose
Ok i need more help... LOL
Im running a 9T 4300kv motor with a 35A esc, 2s 5300 mah 30C lipo. I keep stripping the spur gear. Its the 81T 48P spur gear and im using a 16T 48P pinion. What am i doing wrong? Im more looking to run this buggy with my son so were not looking for alot of speed more looking for a set up that we can have some fun with...Will be using on a dirt track and on the street around the house or at local school. Part numbers would be great.
PLS HELP.
Ok since no one seems to be able to help with this question, The next one is does it matter what slipper pad im using? Are the diff ones used for different running types? Ex.. should i be using a different one for bashing then im using for racing? If so can anyone point me to where i can find this info..
one4rose is offline
Old 04-09-2012 | 03:23 PM
  #13534
bilster44's Avatar
Slipper pads would be the same for bashing or racing...as far as the spur gear goes...are you running the gear mesh too tight or possibly too loose? I don't know what else it could be if your pinion/spur gear mesh is good.
bilster44 is offline
Old 04-09-2012 | 03:25 PM
  #13535
There is only one type of pad I am aware of. Use the same ones no matter how your driving. Your stripping the spur either because your mesh is wrong or your slipper is too tight.
goin2drt is offline
Old 04-09-2012 | 03:28 PM
  #13536
Im not sure if its to tight or to loose. I put a piece of paper in between them and then tighten the screws. Im planing on buying a 81T spur gear and a 48P 19T pinion see if that helps. Right now trying to run a 16T pinion. Is the 19T a bigger gear? Size wise?
one4rose is offline
Old 04-09-2012 | 03:43 PM
  #13537
As long as the pitch is the same it doesn't matter. I run way more motor and do not strip the spur unless mesh is bad
goin2drt is offline
Old 04-09-2012 | 03:46 PM
  #13538
any tips to get a good mesh then? I have 3 stampedes and dont have this problem at all. Dont understand what im doing wrong.
one4rose is offline
Old 04-09-2012 | 03:47 PM
  #13539
Default Pusihin,on power
Hey all,
tried searching threads and found a few.... I just built a B4.1 worlds. I installed a LRP ESC and a 17.5 Rev Tech. I am pushing like crazy (on power, off power it will turn) I have a small amount of toe in, but dont think its too much. I have read that it may be that the diff is too tight. Any help, and how would i loosen ball diff if it is too stiff?
thanks
A.T.
AfterTithes is offline
Old 04-09-2012 | 03:52 PM
  #13540
SoccerSting's Avatar
well thanks...
Those are the regular shocks with aluminum caps on them
Edit: Maybe not, the caps look like they are two different colors.
SoccerSting is offline
Old 04-09-2012 | 04:11 PM
  #13541
So is what I do is push the motor all the way against the spur. Then I pull it back just a tiny bit. Hold the pinion and make sure the spur wiggles ever so slightly. I check the wiggle at 4 different spots on the spur as they are not always perfect. As long as it wiggles in seems to work for me.
Sorry that may not help ;-)
goin2drt is offline
Old 04-09-2012 | 04:38 PM
  #13542
bds81175's Avatar
Moderator
...wiggle, wiggle, wiggle....
bds81175 is offline
Old 04-09-2012 | 04:53 PM
  #13543
mdwaeracer's Avatar
2 ways you can do this that are super easy. Take a pinion 1 size larger and put on motor and tighten motor so pinion is tight meaning no wiggle, then install pinion you want on. should give you exact play wanted or take a piece of notebook paper, make it roll it between the spur and pinion tighten motor and remove the paper. Both methods work and will give u the idea of what correct mesh is,
mdwaeracer is offline
Old 04-09-2012 | 05:08 PM
  #13544
mxracer458's Avatar
they are ae shocks with the blue alum caps,some people like them so don't,i prefer the stockers with the bleeders
mxracer458 is offline
Old 04-09-2012 | 05:20 PM
  #13545
t.mathewson's Avatar
this reminds me of all the slop in the rear of my buggy..
t.mathewson is offline
