RC10B4.1 FT/WC
Old 04-02-2012 | 10:56 AM
  #13351
Dane's Avatar
Originally Posted by Leadfinger2011
Agree on the Reedys for sure but has anyone tried the Thunder Powers. I did just for the heck of it and Dang, it was faaaast.
From what I have heard the TP motors are similar to the Reedy motors. Looking at the design they sure build similarly.....
Dane is offline
  #13352
Dane's Avatar
Originally Posted by elecRC23
Hey guys, i was looking at buying the Associated ball diff for the b4.1. What are the pros and cons of it, and should i buy it? I run at OCRC Raceway, i think it has a dirt/clay mixture, pretty good grip.
The fast guys use it. That's all.
Dane is offline
Old 04-02-2012 | 11:18 AM
  #13353
J_Bone's Avatar
Originally Posted by Slashed Income
Does anyone know the thread size on the Jconcepts hex adapter clamping screw? I need to replace one.
Use 2mm x 6mm bolt. JC uses 2mm x 4mm and it's just not enough threads.
And no, they are not to long and do not stick out.
You will find these in the Airplane section at your LHS.
J_Bone is offline
Old 04-02-2012 | 11:22 AM
  #13354
J_Bone's Avatar
Ball diff's are much lighter (don't rob as much power) and are easier to adjust to changing track conditions.
J_Bone is offline
  #13355
Aoh
before u buy it. i am assuming you have a rtr. just sell it right now and buy the Factory Team, u will thank me in the end.
and to answer your question, yes most ppl prefer the ball diff, i dont know of anyone running a gear diff when given the option.
Aoh is offline
Old 04-02-2012 | 11:50 AM
  #13356
Pro's: you can fine tune your diff to your liking depending how loose or how tight your set it. It puts power down to each side when needed.
Con's: Takes a bit more maintenance like checking tightness and more frequent rebuilds. Gear diff is like the RONCO "set it then forget it" for longer intervals than the ball diff. Overall the performance gain out weighs the con's. Although there are those that say otherwise I'm sure.
jamr1130 is offline
Old 04-02-2012 | 12:01 PM
  #13357
elecRC23's Avatar
Thumbs up
Okay, thank you very much guys!
elecRC23 is offline
Old 04-02-2012 | 12:02 PM
  #13358
microrcdude's Avatar
Originally Posted by MOmo
So I've searched thru this thread, and I wanted clarification:
- Gearing for 17.5
w/ no timing - 78t Spur and gear to the moon (biggest pinion possible)
- Mod - Depends on timing, 81 spur and 20-26 pinion?
Local track runs a 17.5 no boost, blinky class. I just picked up a Peak 17.5 for now, till some other motors come in, but wanted to get some clarifying info answered.
I did a quick test, using an 81 Spur with a 30T pinion, and it didn't feel all that fast.
MOmo
Chris, assuming you're talking about PRCR, start at 30/75 and go from there
microrcdude is offline
Old 04-02-2012 | 12:08 PM
  #13359
Ah Ha just the info I was looking for. I stripped the one of the hexes on my SC10. Thanks.
jamr1130 is offline
Old 04-02-2012 | 12:58 PM
  #13360
onefast8's Avatar
So when running the Losi pistons, What is everyone using to "shim" up the slight size difference? Anyone have a part number?
onefast8 is offline
Old 04-02-2012 | 02:17 PM
  #13361
kurtblastoff's Avatar
Any body running the MIP bypass1 pistons If so how are they and how do you tune them?
kurtblastoff is offline
Old 04-02-2012 | 07:57 PM
  #13362
Wickedclown's Avatar
know this has been asked already just too many pages to look through. How can i get more steering from my buggy i have 2 washers under ball stud on front shock tower. would removing these help if yes. one or both? run on hard pack dirt slight dust. running losi prescub 3 rib pink front tires
Wickedclown is offline
Old 04-02-2012 | 08:13 PM
  #13363
idrummerboy13's Avatar
try 1 less washer, softer spring, maybe taper pins will work better? I change between no and 1 washer in front. Never liked 2
idrummerboy13 is offline
Old 04-02-2012 | 08:17 PM
  #13364
I used some motor shims I had laying around from some old brushed motors.
I believe they were .012 thick.
Brian L is offline
Old 04-02-2012 | 09:20 PM
  #13365
Ball Diff won't make you faster, it'll actually slow you down the 1st couple tries as you get used to building them. Eventually, you'll want one.... if you know someone who can build and set one for you... that would be best way to learn the 1st time.
BTW, OCRC is an awesome clay track that can be loose without some Tire Sauce.
Kuya_Kimo is offline
