Like Tree5Likes
SC10 4x4 Thread
Old 01-27-2012 | 07:59 AM
  #15916
OK, I got my truck back together with new ider gears, clutch basket and the pro4 4600. WOW! Clearing the triple most every time now and those 32 pitch gears sound so badass. I was running my MMP in full sensored mode with "normal" timing (8* I think) and she was running too hot. I switched it to smartsense mode with the same timing and had about a 40 degree drop in temp. So, those with the MMP and sensored motor, which mode are you running your MMP in? I hear that smartsense is supposed to run more efficiently at high speeds. I think the 4600 is very controllable in this truck and faaaassssst. WHat is too hot for this motor? I think I'll add the yeah fan.
riverdog is offline
Old 01-27-2012 | 08:04 AM
  #15917
Resqnu's Avatar
Default Diff question
Im building new diffs and need advice on 2 things.
1. Can anyone comment on adding a 5x11.5x0.2 washer on the diff cup help limit movement and leaking?
2. Top idler shaft has some in and out, is this normal?
Resqnu is offline
Old 01-27-2012 | 08:11 AM
  #15918
Chad Smith's Avatar
When I ran a MMP I ran it in sensored mode so that I could use boost. Once you switched to "smart sense" you must not of been running boost anymore which is why your temps droped. To run "CHEAT" or "boost" you have to be in sensored mode so I dont see how you where running the same timing when you switched. You do not need 8* of boost with that Pro 4 motor though. How hot was your motor when you temped it before you switched to "smart sense"?
Chad Smith is offline
Old 01-27-2012 | 08:23 AM
  #15919
Wild Cherry's Avatar
Originally Posted by BlueGlowBoy
Looks like they are showing it on an SC102wd.... you know, because the 2wd has had so many problems with handling the massive torque required to get it's 3.5 pounds running with a 7.5T 540....
Guessing your joking , but my 2w SC will also get that new Ae slipper as soon as available....
Wild Cherry is offline
Old 01-27-2012 | 08:54 AM
  #15920
vito's Avatar
Originally Posted by Cameron Kellogg
Spy shots of the new AE slipper.
thebigrc
nice find. new gear and cover i hope it looks nice. look like 3 pad set up
vito is offline
Old 01-27-2012 | 09:13 AM
  #15921
beyondthepack's Avatar
Looks cool, hoping the basket is not made out of plastic. Havin't had any slipper issues with My 6.5 550 Tekin, but that could all change with My new Sonic 4.5 550
beyondthepack is offline
Old 01-27-2012 | 09:15 AM
  #15922
Cain's Avatar
are the 4 pole 540 motors ROAR legal?
Cain is offline
Old 01-27-2012 | 09:20 AM
  #15923
IRM616's Avatar
thebigrc
i wonder if theirs a difference between this and rc shox center diff???? anyone
IRM616 is offline
Old 01-27-2012 | 09:26 AM
  #15924
Mac The Knife's Avatar
Yes, this is a slipper clutch,,, the center diff is a,,,,, differential. And if AE's basket is plastic,,, I'll stick with my aluminum, heat dissipating, clutch basket.
Mac The Knife is offline
  #15925
IRM616's Avatar
what's the best way to run my yeahfan? i need it to run fast and good.
IRM616 is offline
Old 01-27-2012 | 09:29 AM
  #15926
Cain's Avatar
+1 . it does look like plastic.
That is one serious spring.
Cain is offline
  #15927
IRM616's Avatar
so most likely when AE comes out with that nobody is really going to jump on that? it seems like the stuff here is better? Im going from basket to center diff as soon as it comes in(next week).
I wonder what would happen if i put the clutch basket on my t4?
IRM616 is offline
Old 01-27-2012 | 09:40 AM
  #15928
Cameron Kellogg's Avatar
The fan will work off of battery voltage, not all fans will, and will move the most air that way of course. I solder the leads right to the battery leads on the speed control post. Down side is I have to reach under the body to plug in the battery before the round starts. The up side is you can leave it plugged in while marshalling and you motor will be cooled off when your done.
You can plug it into the speedcontrol but with a transponder, glitch buster, servo and speed control I am out of plugs. Plus this would be just one more thing running off of your BEC. My servo is a hog as it is so that is not an option.
Cameron Kellogg is offline
Old 01-27-2012 | 09:46 AM
  #15929
Not legal for National events yet, and I think not for regional events either.
Old 01-27-2012 | 09:50 AM
  #15930
IRM616's Avatar
maybe buy a very small switch and run it thru the positive wire on the fan so it wont be on while its plugged in????
i dont use dean plugs but direct so would i just solder it to the bullet connectors? i run saddle would i be able to use the bridge connector??
IRM616 is offline
