SC10 4x4 Thread
I love my SC104x4 even last season when I was running it mostly stock, 3mm washers under the inner camber links, HD pads inner and outer with a Tekin 5.5T and an RX8. I can't wait for the next season. I just finished putting the truck together with swaybars, garodisks, dual-stage pistons...I think the next time it will hit the track is at the end of April at the Motodome....no indoor offroad here, and I refuse to put that truck on snow....
I looked back as far as I could stand to...
Is anyone using the aluminum idler gears? I am interested if they are louder and if anyone has damaged the other gears using them. I want to get an extra set of gears to have on hand. Thanks.
Don't feel those are metal idler's are necessary .
They will most likely be noisier, would be stronger though....
If you do go with ?
The rear transmission would be where to install , leave the ft alone .
The ft end does not experience the load the rear has ..
Sup Jim
If you do go with ?
If you do go with ?
i had the hotracing hard anno idler gears,and they wore out very quickly. The annodize didnt stad up to the steel topshaft.
Anybody running the sitck pack battery down the middle have any feed back regarding performance? I was curious how it changes handling particularly if you know how it compares to inline or side by side saddles.
I haven't run saddle packs but from the description of the handling from guys who have it is very similar. If you notice they all say that inline with weight as close to centerline as possible improves handling. With a stick pack down the middle the weight is as close to the centerline as possible. It takes some work for everything to fit but can be done.
Thanks guys for the help! So would these fit ok?
http://www.hobbyking.com/hobbycity/s...ehouse%5F.html
I'd like to get the nano-tech 65-130c but I didn't see any in the USA warehouse. I'd like to get them asap.
That should fit without issue. Dont forget to keep the page open for a few mins before you add it to your cart so you can save a few $$$.
I run a rx8 with tekin 4p 4600 now. Great combo
5Likes
