Like Tree5Likes
SC10 4x4 Thread
Old 01-28-2012 | 07:53 PM
  #16036
Originally Posted by Misfit138
You are correct sir. Yellow in the front blue in the rear. I had it backwards in my post.
Is there a new sway bar kit out? My kit only came with Yellow, White and Black. Currently running Yellow front and back. Wanted to soften the rear a bit. Is the blue sway bar comparably to the black or white?
Schlong Connery is offline
Old 01-28-2012 | 07:58 PM
  #16037
CoyoteSlash's Avatar
the new "same" kits added 1 more.
CoyoteSlash is offline
Old 01-28-2012 | 08:02 PM
  #16038
MantisWorx's Avatar
Originally Posted by Mizchief
That's the question I have as well. Lots say the 4600 pro4 is too much, but I think it might be the way to go when running the exotek and/or running more weight since it's what the losi guys use on their heavier trucks.
Well one of the things i was trying to accomplish today was better " in air" corrections so i change my gearing to 15/58 but kept the same boost/turbo profile i had. Good news is that it worked very well and the truck was a beast but temps went up to 200+ from 175. so i dropped boost and turbo timings both down 10* and temps went back to 180 but didnt feel as monstrous as before! may pick up a 4600 tomorrow. The weight and/or gear ratio was too much. I think with just the Exotech the 4k is fine, thats what i have been running for months with lots of boost with no issues.
MantisWorx is offline
Old 01-28-2012 | 08:16 PM
  #16039
JEFFs SC10's Avatar
Bigger track ? The bigger batteries added the weight you wanted or did you add more? Mine has a 4600.
It wont hit aa hard initially but itll.ramp up.
JEFFs SC10 is offline
Old 01-28-2012 | 08:37 PM
  #16040
A tooth or two lower 4600 isn't hitting as hard as a geared 4000? hm...
I still think I should have gotten the 4600. Should have gone over necessity instead of thinking "perfect".
Old 01-28-2012 | 08:53 PM
  #16041
tom2tone's Avatar
R/C Tech Elite Member
Originally Posted by Smithy79
Hi,
The NanoTechs will fit. I use them and they fit fine. You'll find they're 49mm wide, not tall. Make sure you order the castle creations bullet plugs though. I have melted the positive terminal on 2 batteries because of the 'cage' type plug. (high resistance connection). You want the best surface to surface contact. The cage connectors just don't cut it. (recommended to me a few pages back, and it has solved the issue)
Originally Posted by jimmer411
5300mah fits perfect. The 5600mah might fit.
I run foams in front of the battery.
Originally Posted by Chad Smith
Yes you want a high C rating. I would recommend the 65C-130C Nano-Tech lipos. (I think thats the C rating)
Thanks guys for the help! So would these fit ok?
http://www.hobbyking.com/hobbycity/s...ehouse%5F.html
I'd like to get the nano-tech 65-130c but I didn't see any in the USA warehouse. I'd like to get them asap.
tom2tone is offline
Old 01-28-2012 | 08:54 PM
  #16042
MantisWorx's Avatar
bigger batts and i also added a bunch of weight, went dramatic just to make sure i could feel the difference. Coyote are you using boost with your MMP/4k? if not you need to add 35* from 5k to 25k and gear it 15/60
Old 01-28-2012 | 08:56 PM
  #16043
I'll do just that and try tomorrow. (if it doesn't rain like the man says is going to.)
Old 01-28-2012 | 10:10 PM
  #16044
jsamarin's Avatar
I thought tall saddles made the truck handle worse than with regular height ones? this was along time ago, so i might be remembering it wrong lol
jsamarin is offline
Old 01-28-2012 | 10:25 PM
  #16045
Cain's Avatar
Tech Legend
How loud should the SC104x4 sound under power? Getting it ready for tomorrow and I noticed it just sounds loud compared to my 2wd SC10 and T4.
Cain is offline
Old 01-28-2012 | 10:35 PM
  #16046
It's definitely not a t4 or sc10 but it's still silent compared to a Slash or Ofna/losi.
Might check the belt cover for warpage and rubbing on the belt causing noise, Or an idler is wearing out, OR your spur is. But it gets a little louder as stuff wears in.
Old 01-28-2012 | 10:48 PM
  #16047
Vegatron75's Avatar
These aren't in the US warehouse, I waited for mine, didn't take to long.
http://www.hobbyking.com/hobbycity/s...Lipo_Pack.html
I swap between 2 of the 6000, and 1 5600, between my 4x4 and 2x4.
They fit perfect and supply plenty of power...
Oddly enough the 6k packs weigh less than the 5.6k pack.
BTW, stay away from the soft packs, if you can help it.
Vegatron75 is offline
Old 01-28-2012 | 11:30 PM
  #16048
Originally Posted by Vegatron75
BTW, stay away from the HobbyPartz, if you can help it.
Fixed.
Old 01-29-2012 | 12:30 AM
  #16049
Wild Cherry's Avatar
Tech Legend
Brand new should be the quietest car on the track....
Don't use a old pinion gear ....
Wild Cherry is offline
Old 01-29-2012 | 04:14 AM
  #16050
With the MMP/4K I run 7 for Torque Limiting and 30deg of timing from 8K to 17,200 with 15/60 gearing.
I noticed a pretty good top end difference just going to the 60t spur from the stock 62t spur.....like it hit the sweet spot.
Temps are 145F after 5min heat and 165F after an 8min main.
With the wrong gearing and timing this combo is flat on top.
F_ME is offline
