HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
#7546
I have a new Serpent Spyder SCT that weighs in over 5lbs. I am in the market for a new ESC and looking at the Justock Spec Race but have concerns that the truck is too heavy to use with this ESC. Plan on running 17.5T Blinky class.
Does the weight of the vehicle affect the performance of the ESC?
#7548
#7550
Hey guy's. Just purchased a V3.1 Stock Spec. Im curious to know if it comes in blinky mode out of the box? Im running 17.5 blinky class. I calibrated the esc to my radio and it seems like it has timing/and boost beacause my tires turned into pizza cutters. Also can I program the esc without the program box to blinky mode? If so how? Thanks for your time guys.
#7551
#7552
#7553
Well I decided to try and update my new stock spec v3.1 to see if it would stop shutting off mid run and now it is what they call bricked. I get the power on, servo works but can not shut it off, programming box and computer will not connect to it. So far not real impressed.
Paul
#7555
Is blinking green light on the on/off switch blinky? I really doubt it set to blinky out the box this thing rips. Or is it just that badass of a Esc?
#7556
[QUOTE=Slotmachine;13501351]Hobbywing knows there were a few units that went out that were bad.Hobbywing stands behind their products and will replace the unit. Please fill out an RMA form from the falconsekido.com site and send it in for replacement. Im willing to bet your other problems will fade away also.
Is there a contact for HW on here? I pulled it out and installed my 120amp v3.1 for now. I am new to HW, have ran almost every brand out there. I bought a brand new 120 amp 3.1 from my LHS and then found the stock spec 100amp on here, it was new in the box never soldered up. I have pics of it new and the listing. I looked at the RMA form and it requires a receipt, I have my Paypal transfer and documentation from purchasing it on this site. Will HW stand behind it since it's a known issue without me having the original receipt?
#7557
[QUOTE=Crowbo74;13501420]
I would contact them and ask. They have great customer service!
#7559
He does not work at Falconsekido.com, you need to contact someone there. Email them and give them some time to respond.
http://www.falconsekido.com/pages/contact-us
#7560
A green light means either throttle or brake is being applied. If the V3.1 is in blinky mode, the on/off button will blink with a red light when in neutral. If it's a blinking yellow light, that means you have a sensor problem (either the sensor wire or the sensor board in the motor).
