Speed Passion Thread >
Like Tree4Likes
Old 11-05-2013 | 08:52 PM
  #4081
Wildcat1971's Avatar
well, I cant get them for $26, but they are still cheap.
Wildcat1971 is offline
Old 11-05-2013 | 11:43 PM
  #4082
zeakemedia's Avatar
Are you talking about the ultra sportsman or the V3 competition? I've used and enjoy both. Ultra sportsman are $30, not $26, and the V3 competition are $38 on the SP website. The ultra sportsman is the one I abuse. I put gearing to it that makes my truck fast and don't worry about it.
Blake
zeakemedia is offline
Old 11-06-2013 | 03:48 AM
  #4083
Rampidhsd's Avatar
Has there been a resolution or acknowledgement of the cogging issue with the RP 1.1. I'm having the same issue but it is only when I first set the car down or let the car sit idle for a period of time. Mine also seems to be running a bit on the hot side (155). It's in a b44.2 with a 7.5. Have tried different gearing, different servos, different motors, sensor wires. Have tried different 30mm fans to try and help the heat up issue also. Nothing helped more than a degree or 2 and nothing changed the cogging.
Rampidhsd is offline
Old 11-06-2013 | 04:42 AM
  #4084
Blake
v3.0 comp.
Old 11-06-2013 | 07:09 AM
  #4085
Cain's Avatar
Tech Legend
V3.0 Comp is a great motor. I have the 8.5 and really liked it in a variety of vehicles.
When it comes to mod, heck, if the other guys motor is more powerful, I just grab a hotter one of mine or if it can take it, play with timing / boost.
if anyone needs a 17.5 MMM motor drop me a pm.
Cain is offline
Old 11-06-2013 | 07:24 AM
  #4086
whats the advantage of the MMM? more timing?
Old 11-06-2013 | 07:59 AM
  #4087
The timing and stator are different. It is also a few grams lighter than a V3.0.
Nexus is offline
Old 11-06-2013 | 08:04 AM
  #4088
I just noticed there does not seem to be an 8.5 in MMM. weird. Anyway, a few more grams in mod wont mater. I think I am going to try out the SP 8.5 in buggy, its cheap and if I dont like it, I dont loose out much.
Old 11-06-2013 | 08:10 AM
  #4089
You can always add more timing to the V3 or MMM using different sensor boards. Both are great motors. Sometimes people select the V3.0 because there are more wind choices.
If you look at pictures of many of our top and pro drivers they run both the MMM and V3.0 depending on the wind and track
Nexus is offline
Old 11-06-2013 | 09:49 AM
  #4090
1967Typhoon's Avatar
Is there a KV chart for these motors? I can't find anything. I am going to be picking up a V3 7.5 or 8.5, and I was wondering what range KV these were to know where to start my gearing.
Thanks!
1967Typhoon is offline
Old 11-06-2013 | 10:20 AM
  #4091
Thanks!
What class/vehicle?
Nexus is offline
Old 11-06-2013 | 11:00 AM
  #4092
Originally Posted by Nexus
What class/vehicle?
2wd SCT.
Would really like the KV ratings more than gearing advice.
Old 11-06-2013 | 11:02 AM
  #4093
kv rating are made up number and mean nothing like c rating. Its only relative for a give manufacturer. Comparing a reedy kv to a SP kv would be a waste of time
Old 11-06-2013 | 11:18 AM
  #4094
2wd SCT.
You can find KV ratings in the manual of each motor. Here is a direct link to our PDF on the MMM motors.
http://www.speedpassion.net/uploadfi...eb02nd2012.pdf
Comparing KV and C is difficult across the various brands. That is why gearing on a D3.5 17.5 and a MMM 17.5 are not always identical to achieve optimum performance.
Nexus is offline
Old 11-06-2013 | 11:44 AM
  #4095
OK. In that case, I am running a HPI Blitz SCT on a high bite track. Very smooth track, 3 long straightaways. You need to gear more for higher speeds than for all-around torque. What is a good starting spot? I am at the sweet spot right now with my 13.5T RevTech (4000kv) at that is geared 88/22. I will likely run the 8.5T V3. Thanks for any and all input!
