sapperc - Its a variable step, as you increase -- hence why its much harder hit once you get over 5 (I think over that just starts creating why too much heat in the esc).
Finding that boost set up is a process, but it can be very good. When you find a range that works for you. |
Originally Posted by nikos2002
(Post 12140641)
sapperc - Its a variable step, as you increase -- hence why its much harder hit once you get over 5 (I think over that just starts creating why too much heat in the esc)...
In other words, does a slew rate of 4 equal 4 additional degrees of timing advance per every 1000 RPM above the Finish RPM? If not, then what is the slew rate step formula? Thanks. |
its actually an algorithm of degrees in timing per sec. The higher the rate, the more timing it adds, at a quicker rate. So if your slew rate is too high, it basically dumps all the timing in very fast, making it feel very abrupt and aggressive - but that also makes the esc work harder (more heat).
VTX8 has been so popular it actually sold of our inventory completely!!! Next shipment due to arrive within two weeks. But, we worked out a plan. Check out our new ShopViper Facebook page for details. Like us, and receive updates on price deals, new products, and sales.
https://www.facebook.com/ViperRcShop |
Can I run a VTX10-BE in "Blinky" Mode??? Gonna be running it in a class where I can use no boost or timing.
yes, you can profile number 1 is blinky
Can you guys help me diagnose a problem with my vtx10. When landing a jump it is restarting itself. I have tried putting 2 layers of double sided tape under it and it is still cutting out. Have you had issues like this?
(Post 12140771)
Originally Posted by alexb2000
(Post 12141115)
My Viper copperhead system ran great. I had a friend named Rocha test out a sct for me with the Viper in it. He qual'ed 4th in expert sct and finished on 3.9 sec behind the winner that was running system that cost twice as much...
http://i726.photobucket.com/albums/w...pse02799c3.jpg |
Originally Posted by Wildcat1971
(Post 12141001)
(Post 12141115)
For a Vtx10 http://www.shopviperrc.com/ProductDe...ode=6VSPCAP004 For a Black Edition http://www.shopviperrc.com/ProductDe...ode=6VSPCAP005 |
(Post 12141115)
hi, i have a vtx10 with a 10.5 vst motor, it goes perfect an good, but would like to know what these escs do when they hit LVC? as some stop, some stutter some start an stop.
Originally Posted by LosiPRRACER
(Post 12144102)
| All times are GMT -7. It is currently 12:52 AM. |
