Like Tree4Likes
Viper RC -
Old 03-15-2013 | 05:09 AM
  #7141
OMG23RC's Avatar
guys can someone link me the viper setup sheets?
OMG23RC is offline
Old 03-15-2013 | 05:24 AM
  #7142
godofcable's Avatar
which ESC?
godofcable is offline
Old 03-15-2013 | 05:25 AM
  #7143
Originally Posted by Wildcat1971
fans are normally for 4x4 SC's and 8th scales. Both of which are not coming with the ability to mount the fans to the motor mount. I would prefer that to a messy motor plus heat sink. I would prefer to not use Motor fans period. you gear really high because you have a fan. the fan goes out mid race. motor burns up? If anything I would prefer passive heat sinks.
I would be using it on my 4x4 SC because of the terrain I am in and stress induced on the motor. Thick sand and grass, with bigger wheels requires a high punch and start power with enough torque to continue carrying the truck.
Right now I am using a modified computer CPU heatsink (the circular one from Zalman) and it made a very noticeable difference, at the cost of a couple of grams. I just don't have enough airflow moving through my body to help dissipate the heat. I want to encase the fan inside the heatsink so I wont have to worry about it getting damaged or wet. I will try out the speed control fan like nikos2002 suggested.
boostem is offline
Old 03-15-2013 | 05:30 AM
  #7144
SCSRT8's Avatar
Thanks WildCat and Nikos. I got my set up from Amazon. They had an offer I couldn't refuse. Plus I run the CopperheadR 4500 in my SC10 4X4 and absolutely love it. That truck kills anything in the straights and I can stand it on the nose with the brakes. Still learning how to get out of the corners though..... Maybe too fast in the straights???? I will probably just order the PC link because the brakes are not up to par at all as you said and I don't have time to send it back before the next race. It calibrated first try to my Radio and drives like a dream. If nothing else improves my confidence did. Beautiful piece of work and so easy to mount ANYWHERE. Great work guys. Will be ordering a 10R for the 4wd
SCSRT8 is offline
Old 03-15-2013 | 06:51 AM
  #7145
OMG23RC's Avatar
Originally Posted by godofcable
which ESC?
I have the vtx10 B.E
OMG23RC is offline
Old 03-15-2013 | 06:59 AM
  #7146
godofcable's Avatar
first heres an editable blank
and heres a link to a bunch of different setup sheets from various drivers on various types of tracks
Old 03-15-2013 | 09:42 AM
  #7147
nikos2002's Avatar
Andrew- you can tell them to contact us, we will swap them out for updated units.
Mulepic - Copperhead no, VTX8 yes, but it hasn't been posted on the website yet.
nikos2002 is offline
Old 03-15-2013 | 01:12 PM
  #7148
Wildcat1971's Avatar
so I was checking my esc last night and playing the proguage. When using the servo checker, I noticed it says my bec is putting out 6.79 volts. I was like weird, I set it to 7v. So I dropped it to 6v anf it read 5.79v, then again to 5v and it showed 4.7ish volts. So where has my .21 volts dont, lol. Is everyone else seeing this? I am going to check my other vtx tonight. Also, I picked up a HV servo and esc, so I upped the esc to 7v bec. Should i expect any issues with this setup? less run time, etc? BEC dies faster?
Wildcat1971 is offline
Old 03-15-2013 | 07:10 PM
  #7149
AndrewTom's Avatar
The Servo has to have some power even with no input. that explains the voltage drop.
AndrewTom is offline
Old 03-15-2013 | 07:18 PM
  #7150
nikos2002's Avatar
There is going to be some drop across the system, I have seen similar. As for running 7v as an issue - would depend on the class and motor you are running. If its 4wd SC with a 4 pole motor, maybe not the best idea. Also for 1/10 how twitchy do you really want your vehicle to be?
Old 03-15-2013 | 08:53 PM
  #7151
OMG23RC's Avatar
Ok thanks guys, in the next update it would be really cool if vipers team drivers can post there setups on the viper homepage and then you can load them straight on to the esc, without having to do it manually
OMG23RC is offline
Old 03-15-2013 | 09:15 PM
  #7152
nikos2002's Avatar
Funny you say that..... did you know with the VLink you can make a copy of your settings in a separate file, which can be loaded by someone else with a VLink...... something we are going to start using more of as we continue to grow.
As for right now, if there is a certain type of set up you are looking for PM, I will send you some info
Old 03-16-2013 | 02:49 AM
  #7153
xrayrc's Avatar
YuP that is how I setup new esc's got my profiles
Setup and saved the way I like I just load them into
The new esc drop in car and it's done ready to race
If you need something let me know....
xrayrc is offline
Old 03-16-2013 | 03:21 AM
  #7154
Default Please explain to me......
Don't flame, please. I've searched and read but got tired of "searching" for my answer.
What exactly does "slew rate" do and why would I want to adjust it? Use layman's terms please.
TIA
shagnat is offline
Old 03-16-2013 | 03:16 PM
  #7155
nikos2002's Avatar
Think of it like controlling how a turbo spins up. Higher the rate - harder and faster it spins up (adds the boost), lower the rate - still adds boost little more controllable.
Your slew rate is too high, if you are pulling a wheelie when you get on the throttle (off road), it feels like a light switch (instant on) or your generating too much motor/esc heat.
Generally you would start low, and add little at a time while testing the set up.
