Viper RC -
#3047
#3048
Thecman - Thanks. It was a good weekend. I was really impressed with the dirt and tire wear. I worked with Dan on Sunday and looked over his setup. I drove his car after some changes and it was pretty good, but we had a bit more to look at. Nikos has his contact information and a history of what was occurring and what all we tried.
Nikos - No problem, that is what we are here for.
#3049
So you only miss remembered what was being released, and that was the Info on the Sensoreds 4 poles.
#3050
Im thinkn im really not gonna miss my tekin 4 pole, i just dont thi,nk it was that powerful!! As for copperhead being unsensored, i dont think its gonna matter except for roar sanctioned events, iv never drove my truck and thought sure glad this motors sensored
#3051
Right now the production schedule has VST L motors, VTX1 speedo, and VX4/Copperhead in the short term. Anything else is too much of a guess. And as we all know when developing products putting an exact release date out there is a hard thing to do.
We have a lot of great products right now, and more in the pipeline.
#3053
The original ideas were to have the VTX8 come in as close as possible to the size of the VTX10 series. I haven't seen any actual mock ups or additional work yet - engineers like to keep that stuff pretty secret til they are ready to show it off.
#3056
Love Viper! Great speedo and motors. Wanted to post my setup to see if any of you tech guys would tweak at all. Runs good, just trying to get a bit more. High bite kinda short track with lots of traction. 1 decent straight, pretty tight other than that. Running B4 with Vtx10 and viper 13.5. Was geared at 75/28 but just switched to 75/31. End bell timing is about 22.5 (Btwn 20 and 25) Here's settings: Temps 100-105 after 6 mins
Brake Str. 80
Brake pwm fr. 4000
curve linear
neutral Br. 11%
trig. rpm 1000
m br. str. 0%
Throttle pwm 2500hz
Thr. punch 100%
Thr. curve linear
Deadband middle
Acc Boost
Start rpm 4500rpm
Finish rpm 13,500
Max. Adv. Timing 32
Top Speed
Slew 11/1000
max adv. 15
Run mode modified
holeshot n/a
Thanks for any input!!
Brake Str. 80
Brake pwm fr. 4000
curve linear
neutral Br. 11%
trig. rpm 1000
m br. str. 0%
Throttle pwm 2500hz
Thr. punch 100%
Thr. curve linear
Deadband middle
Acc Boost
Start rpm 4500rpm
Finish rpm 13,500
Max. Adv. Timing 32
Top Speed
Slew 11/1000
max adv. 15
Run mode modified
holeshot n/a
#3058
I have an issue with my viper 8.5 motor when i got it it seamed under powered so i switched my esc from speed passion to lrp now when I set it up theirs no power and seams to want to go in reverse i had a viper team guy look at it he said there was no issue I checked my connections my wires and changed the sensor wire still not working I know my esc is fine because it ran my epic motor fine any help would be great
#3059
spdrac430 - its always good to check all your connections, but if your other motor runs OK we need to look at some other things.
- our motors are more torque based than some others, normally I would recommend going up a tooth or two from what you were geared previously.
- Does the motor spin freely? Is it hard to turn?
- Did you do anything to adjust timing? I saw a customer turn down timing when he thought he was turning it up.
If you still are having issues after looking at those points, I would recommend going to the Viper website (www.viper-rc.com), fill out an RMA for and return it for exchange. 8.5 should be pretty quick if working correctly.
I hope that helps.
Nick/Viper
I hope that helps.
Nick/Viper
4Likes
