Viper RC -
#4546
OK here's the update tried everything you guys recommended. Cleaned all my bearing wheels and tranny, made sure everything spint freely,made sure gear mesh was not to tight, reprogramed car to controller, adjusted timing a lil, and added some punch, but his is still getting higher MPH than me.
Am I missing something.
#4548
hey guys i went to the viper website to download the new firmware and i cant seem to find were u download any firmware all i see is setup sheets and viper logos but no firmware.. can someone point me in the right direction.. thanks.
#4549
#4550
If you have verified that you are getting full throttle, and the mechanical side of the car is good (bearings, call rolls good, transmission rotates freely), I would try going down one tooth, or maybe up one tooth and see what you get for results.
I would verify that the ESC is setup at 10 for forward power, and verify that the Start Power setting is at 5 or higher.
#4551
the
I was hoping that with the extra rpm that I would be able to surpass his car on a even playing field, but it looks like it will turn into who will hit the highest mph with different set ups. I'll report back once I run the cars with different gears
Another ? If we do keep the playing field even and keep changing the gears on each car together should my vx4 eventually be able to run faster
Your motor makes 10% more RPM, so I am assuming that you might be over-geared to the point where the motor cannot over-come the gearing to get up to speed.
#4552
I have the copperhead/5150kv on the way along with the programming card. Im gonna be putting in in my lightweight scte and am looking for some gearing recommendations along with esc setting. I am running on a medium large 1/8 covered clay track with medium traction, and am looking for the edge in speed with this combo. Any suggestions are welcomed
#4553
On MONDAY 4-30 mid-day I got an e-mail confirming that they received it.
On MONDAY evening 4-30 I got another e-mail that it was being processed.
On TUESDAY MORNING 5-1 I got an e-mail stating that it was completed, shipped and they gave me my tracking number.
Couple that with the ease of the whole warranty process, the level of contact through e-mail they had with me, as a result, here's my opinion of Viper-rc:
I'm 31 years old and that is without question The BEST CUSTOMER SERVICE I have ever received from ANY company in my entire life, bar none.
Viper support and customer service A+++++++++++++++++
#4554
I believe I ran profile 4 in the esc but turned the timing down to 3 or 4, sorry I'd go check but I'm only running 2wd now lol...
#4555
So I shipped my VTX10 ESC to Viper on FRIDAY 4-27 for warranty repair...
#4556
I havE a vtx10r and proguage coming my way. It will be replacIng a mmp. I will be pairing the 10r to a lrp x12 8.5 in my kyosho ultima scr what are some good base settings for this thing. I had my mmp in blinky mode with no punch control.
#4559
My settings and setup:
Losi SCTE
NanoTech 6000mah 65C Batteries
13T Pinion / 40 Spur
Punch 3
Motor Timing 1
Brakes 8
Start power 6
Drag Brake 0
Cut-Off 3.0v / Per Cell
#4560
Best advice is to see what others are running at your local track and start a tooth or two lower and test.
4Likes
