Viper RC -
#4532
i do know that there are pics of now on facebook ....i have been told that the first units are being tested now .....and that they are not far off from being ready ...that being said i really havent been given a date ....i was told that after many hours of running the new esc and motor they have had no issues with heat ...which is a good thing.....here is the facebook pic ...look tasty
#4533
got a some what of noob ? I have a rustler with a viper cooperhead esc and vx4.39 in it and my buddy has a stock rustler vxl. Me and him have the same gearing and same battery and i do speed runs on both and his is still faster than mine. Does this sound right?
Thanks in advance for any help.
#4534
there are a few things to look at here
1. have you calibrated your radio to the speed controller via the instructions that came with the system
2. what profile are you running the esc on ...they come preloaded with several profiles for people who dont have the pro-gauge programming card ...again the instructions are a great resource when figuring out the profile you need
3. get a pro gauge if possible ...which will allow you to modify the settings to your liking
try these simple things first ...you should be pulling wheelies soon ...let us know how it turns out
#4535
#4536
twonb1- like Brian said, the profile on the esc can make a difference, but remember its also going to effect things like heat as well, so be careful with the changesn
Also a good thing to check is to make sure you transmission is as free spinning as possible. Bearings clean and working correctly. Nothing binding (like wheels too tight or screws too tight. When you have two set ups that ate the same, it's the little details that can make a big difference.
#4537
Im running profile 1 Street Mode
I have one just haven't touched it yet at all.
Yes with both have the same tires/wheels and bearings
He was getting 6 to 7 mph faster on the same battery.
Thanks guys for the help.
#4538
But if he is running profile 3, 4, 5- he will have a mechanical advantage. And you do have to careful. You would be amazed how two of the same vehicles (RTR or not) can have differences in how smooth everything spins. If you take off you pinion gear and spin the wheels, the free it spins the better.
#4539
How is the copperhead doing in the Losi SCTE? Looking at the 4500kv setup. We normally run 10 minute mains for the pro series so being able to run 10 on a large wide-open track is a must. I would have an Orion Carbon 6500 2s that I would use for the mains. Do-able?
#4540
#4542
Very smooth motor
#4543
#4545
OK here's the update tried everything you guys recommended. Cleaned all my bearing wheels and tranny, made sure everything spint freely,made sure gear mesh was not to tight, reprogramed car to controller, adjusted timing a lil, and added some punch, but his is still getting higher MPH than me.
Am I missing something.
4Likes
