Like Tree4Likes
Viper RC -
Old 06-01-2011 | 11:55 AM
  #1681
smokinu's Avatar
Originally Posted by TopAs
I think I set the temperature shutdown too low --- I measured the motor and the ESC - 156F is not too much .... I will raise the ESC to 220F and motor 200F
i disable the motor temp cut off.. if you gear right, out side can temps should be in the 130-155 range.. that is typicaly where i try to keep my motor temps
also if you gear right the motor should not get any hotter no matter the run time.
smokinu is offline
Old 06-01-2011 | 03:46 PM
  #1682
Fabulous's Avatar
Originally Posted by smokinu
I dont know why you would want to ditch the ones that come with it, they perform just fine for everyone and a couple top level drivers.
What are your's doing that no one else has an issue with yet?
No issue, only asked if it would work.
Fabulous is offline
Old 06-01-2011 | 04:16 PM
  #1683
bigfred819's Avatar
Originally Posted by Manshoon
Anyone know the status of the 1/8th scale stuff yet ?
Thank you
+1
bigfred819 is offline
Old 06-01-2011 | 04:31 PM
  #1684
smokinu's Avatar
Originally Posted by bigfred819
+1
motors are almost finished. Esc's are being tested and prototyped. thats all i know.
smokinu is offline
Old 06-01-2011 | 04:45 PM
  #1685
Dlewis4's Avatar
R/C Tech Elite Member
Motors are almost finished, but speedo's havent hit the states for prototyping and testing... looking a few more weeks before testing begins. Should go pretty smoothly considering the 10th scales have gone over so well.
Dlewis4 is offline
Old 06-01-2011 | 06:34 PM
  #1686
I am using the VTX10R with a 6.5T motor in a durango 410 on a small grass track .... ESC and motor are getting way too hot . (I use the standard profile 2). What can I do to keep temperatures down (I set the shutoff to 190F for the motor and 220F for the ESC)
Gearing: 20T
I just set my motor cut off to 230. I had it at 200 and it shut down on me at 150/160
bring it on is offline
Old 06-01-2011 | 06:45 PM
  #1687
nikos2002's Avatar
FYI - if you check out the Facebook page - there are some shots of the factory engineers testing in Thailand in 100* heat. If they can make it there, they can make it anywhere!!!!!!
nikos2002 is offline
Old 06-01-2011 | 06:46 PM
  #1688
arg! are you going to run Nats next week?
You mean the gas nats at thunder alley? Nope, thats for all them gas racers, haha. I havent run gas in a while, got tired of all the headaches from the smell of nitro.
Been playing with some of the settings on the esc and motor and wow i woke this thing up. That drive pwn freq really makes a big difference, just a note for all, make sure you adjust it in small increments and watch the temps.
hacker07 is offline
Old 06-01-2011 | 06:47 PM
  #1689
nikos2002's Avatar
Please remember as well that when you are measuring 156 on the outside, the internal temp can be higher - that is what the VTX is looking at.
Old 06-01-2011 | 07:17 PM
  #1690
Hey Nick how was Disney World!?
Poptartninja is offline
Old 06-01-2011 | 07:23 PM
  #1691
Dlewis4's Avatar
lol
Dlewis4 is offline
Old 06-01-2011 | 09:35 PM
  #1692
Cult Racing's Avatar
Is there a way to reset the esc? When i first got my 10r it ran awesome, running a tekin 4.5 in my ae 4x4. Well then i started to change some settings and now i cant even do a 5min main and the motor is about 110-130 and esc is around 100-130.
By chance can it be the battery cutoff? Because i messed with that and tried to get some help and couldnt figure it out
Cult Racing is offline
Old 06-01-2011 | 10:58 PM
  #1693
smokinu's Avatar
it could be.
what is the battery cut off at?
i run mine at 3.1v per cell.
smokinu is offline
Old 06-01-2011 | 11:10 PM
  #1694
it could be.
the lowest my battery voltage cutoff goes to, is 4.6. It wont go any lower, but the thing that confuses me, is when i first ran it, it was the stock settings which worked great, but then when i did a couple changes and ran it would stop about 3:30 - 4min into my race. Im running the xcelorin 6000mah 60c batts
Old 06-01-2011 | 11:13 PM
  #1695
smokinu's Avatar
i think they cut off is for a total voltage i would go to 6.2v and see if that helps.
what lights show on the esc switch after it stops working?
red and orange solid?
smokinu is offline
