Viper RC -
#1711
Is it just a solid red light that is on?
#1712
#1713
WTH......It's been like 4 hours since I read the thread last........So are the 1/8th motor done yet.......Or better yet...What do they look like where are they being tested...who is testing them ...what are there test results...when are they going to be out again....lol.....It sounds just like when the 1/10th stuff was coming.....It's coming and when it comes it will be great along with being backed by great customer service....so please be patient!!!!!!!
#1718
Re-check all your solder joints - just touch them up to be sure - even plugs (or banana plugs if you use them). In testing with a driver we were having an issue were it would cut off all by itself, after changing all the electronics twice, we found a bad solder joint on a banana plug.
#1719
#1720
Lol
#1723
its probably self clearance now to the highest of tolerances cant get any worse i guess.
there is a spring inside on the rotor to keep it inline. make sure not to loose that.
#1724
never seen that on any of my motors but its been sometime since i tore my 8.5 apart after running it for a good 15 packs or so.
4Likes
