Viper RC -
#212
So I am interested in picking up one of these motors to try, but I am concerned with the really low Kv ratings. Comparing the 10.5T to a Tekin 10.5T there is 1400Kv difference
I understand there is much more to a motor than KV alone, but what about spec classes where gearing is often already at the limits of what will fit?
I like the look, and I like that you guys are here helping racers, but you gotta tell me the numbers are VERY conservative or something.
#213
I can tell you with the viper motors you have a bit more room in gearing then with what you have now. I can honestly say the viper motors are hands down better then my losi and my novak. I had a novak 13.5 on my cougar and ran a 28 pinion, I swapped in the viper and used the same gearing and it was exact.
I had lower temps so I was able to bump up to a 30 tooth pinion and got a bit more speed out of it. all in all I will be running only viper for electric.
I just recieved a 8th scale motor and will have everything installed in my losi tekno conversion in the next few weeks and will be testing them on 22 volts!!!!!
cant wait!
cant wait!
#214
Typically the Viper motors Gear 1-3 tooth more then other motors of the same wind.
in 13.5 buggy
i ran 26/75 in ae b4
i now run 26/78 and my car feels the same.
but my motor is more efficient on bottom end, And smoother through the whole power band.
#215
cant wait!
cant wait!
#216
They should be out pretty soon with the Results of the snow birds
Weylin and the Crew should be back home and online tomorrow!
#219
#220
I geared up 3 teeth thinking...wow I would never try that with any other motor and ran hard for 6 minutes both 17.5 and Truck was a blistering 88.5 and SCT was 101.8 lol.....I am now waiting on smaller spurs because I had no more room to gear up anymore.............Come on SPEEDO's...I am loving the new motors ..what a difference
#221
So, ah, couple days after the Snowbirds, any new news? (even if it means later?) Waiting on ordering 2 10.5 VST's, a vtrax10, and a vtrax10r
Do have a question though on the ProGuage. I believe I saw earlier in the thread, that the plan was to include the ProGuage, I was wondering on what? With the ESC's, or only packaged in with ESC and motor combo's? Our local track is under construction, so not in a major rush so I've been holding off on getting motors, so I could get a combo. Or even if the plan is to offer combo packages?
.Do have a question though on the ProGuage. I believe I saw earlier in the thread, that the plan was to include the ProGuage, I was wondering on what? With the ESC's, or only packaged in with ESC and motor combo's? Our local track is under construction, so not in a major rush so I've been holding off on getting motors, so I could get a combo. Or even if the plan is to offer combo packages?
#222
Weylin will update the thread when he gets back online!
#223
#224
#225
Get your self a couple Vipers, they are bulletproof man!
In fact... we have quite a stock of Viper motors at Premiere!
4Likes
