Like Tree4Likes
Viper RC -
Old 05-27-2011 | 08:16 AM
  #1651
R/C Tech Elite Member
Thank you sir that is awsome..
OK now i am puzzled plugged the servo into my VTA car with same reciever and battery just a losi speed control and it works great seems like the viper speed control BEC just has no amps.
BIGTRUX is offline
Old 05-27-2011 | 11:04 AM
  #1652
smokinu's Avatar
did the viper speed control run the servo before you messed with the tester? try another servo on the viper speed control.
through the pro gauge the esc has an adj bec from 5v to 7v in small increments.
smokinu is offline
Old 05-27-2011 | 11:05 AM
  #1653
may i know how to increase brake strength? i set it to 100% but it still seems weak?
thanx
chiatw73 is offline
Old 05-27-2011 | 11:09 AM
  #1654
smokinu's Avatar
thanx
adj the pwm frequency
and on what esc
the 10 or 10r?
on my 10 at 100% break it would lock up the tires on my b4.
also what motor are you running it with?
smokinu is offline
Old 05-27-2011 | 11:51 AM
  #1655
Tried 3 different servo's. 2 Hitec servos make the lights blink crazy and nothing happens I tried a KO servo and it works but it has almost 300oz torque and just barley seems to have the strength to move it but when I plug it into the tester and hit swing mode it slams back and forth like normal? I wish I had another speed control to test this against.. I took every thing apart from my offroad truck and my onroad car and switched and moved everything and the only common I can find is that my servos do not have enough amps with the viper setup..? I think the pro guage was just a coincidence. any one else have a similar problem?
I am gonna try and touch up all the solder joints again maybe I got a cold joint and it is just not delivering the current I need..
BIGTRUX is offline
Old 05-27-2011 | 12:01 PM
  #1656
smokinu's Avatar
up the bec in the pro gauge on the esc to 7v
smokinu is offline
Old 05-27-2011 | 12:08 PM
  #1657
I get Tekin at a 60% discount and quit using then because of faulty product and slow return's.Last fall I missed 3 races waiting to get a bad speedo replaced. Every thing has lemons that is why they have return policy's in place, the key is what they do after they have been noticed.
BIGTRUX is offline
Old 05-27-2011 | 12:26 PM
  #1658
Originally Posted by bscopes
buy tekin or buy twice
Boy, somebody sure feels threatened by these new Viper products!
CraigV is offline
Old 05-27-2011 | 07:04 PM
  #1659
Manshoon's Avatar
Anyone know the status of the 1/8th scale stuff yet ?
Thank you
Manshoon is offline
Old 05-27-2011 | 07:33 PM
  #1660
and on what esc
the 10 or 10r?
10r. the pwm freq is at 2500, using the Tekin sc4x6.5.. practice mode.
at 100% the braking is only slightly better than drag brake?
btw for forw/rev mode(practice) there is no pause between forw/rev?
what is race modified mode?
thanx and sorry for so many Qs..
chiatw73 is offline
Old 05-27-2011 | 10:21 PM
  #1661
Thank you
I was in LA, California testing a viper 1/8th buggy motor at west coast rc race track. Here is a video http://www.youtube.com/watch?v=ettI_icRJBw
bring it on is offline
Old 05-27-2011 | 10:22 PM
  #1662
Here is my blitz running a viper esc and 10.5 motor. I have not yet got the esc over 105 degrees.
http://www.youtube.com/watch?v=yD3VxdO0XQQ
Old 05-28-2011 | 09:35 AM
  #1663
and on what esc
the 10 or 10r?
update: found the problem.. i had set the epa for rev to abt 40% as there was no need for me to do reverse fast. and that had affected the brakes. thanx
chiatw73 is offline
Old 05-28-2011 | 05:56 PM
  #1664
JS's Avatar
JS
Blitz looking planted Rick. RTR or ESE?
Good to see a Blitz out there at WC. Last time I was there, I was the only one with an ESE.
FT SC10's everywhere. One or two XXX SCT and a couple of Kyosho SCR's.
Off topic - But would you be able to share your setup at WC.
I was running 35/30 oil, AE Blue/Gold Spring, B/B piston, 30k Gear Diff, 30mm Ride Heigh front/Rear. Also using the Silver 5* front bulkhead.
It runs great and planted.
thanks, Jeff
JS is offline
Old 05-28-2011 | 08:23 PM
  #1665
Well I have tried every thing I can possibly do and come down to the fact that I just have a junk speed control I guess. gonna bring it with me to the track tomrow and see if any one else can see some thing I over looked. But this will be week 3 of our points and I sat out the first 2 weeks waiting to get it and now it does not work.. I am sure it will be worth the wait when I finally get it up and going..
BIGTRUX is offline
