OS 12 TzR
#751
Originally Posted by thefuzzclub
the 5port sure has a wide carb. anyone tried running the engine without restrictor? will it produce more punch? speed?
#752
Originally Posted by nero1943
I have a TZ (p) 3 port. I assume it's possible to get the 5 port piston, sleeve, con rod, and crankshaft? I already know a 3 port performs now I wanna try a 5 port.
you can switch between the 3port p/s and the 5port. i have a set of both because i was racing in a roar event so i switched to a 3 port p/s set with no problems. you just have to tweek the needles but if you have money to buy this engine then that should go without saying
#754
So i have a TZ 3p and it has been running great, however the track that i run on is small so i have never really streched it legs, so my friend who has a radar gun and i tested it in my mtx3 the other day, When i thought the motor was about to top out RPM it just kept going, needless to say even with my gearing for a very small track the car still hit 56mph, i just couldnt belea ve how much more top end there was that i have never used.
#755
Originally Posted by Aphinity
Do you have to change the conrod and crank to switch from a 5 port to a 3 port, or is it just a piston and sleeve change?
its just a piston and sleeve change. i'm thinking about getting a second conrod though because then i dont have to keep popping out the piston pin retainer...when those things fly across the room, forget about it!
#758
Hi Guys,
I was wondering wich glow plug to use for my new engine.I'm going to start break-in today, What type of fuel and what type of glow plug should i use for the break-in procedure.And what type of fuel and glow plug to use for racing.
I live in Middle east, so its very hot and humid.
#760
Originally Posted by moot
the cranks and carbies are different too.
3 Port:
http://www.gpmd.com/cgi-bin/wgpprt100p?&I=OSMG1997
Crank = Stock number OSMG4487
5 Port:
http://www.gpmd.com/cgi-bin/wgpprt100p?&I=OSMG1998
Crank = Stock number OSMG4488
#763
I ran my car in a parkin lot the other day. I didnt noticed that after a while the teeth of my 2nd gear was completely damaged. and for about an hour Im doing a full throtle not knowing that my 2nd gear was broken. then I noticed my engine stop running, I tried starting the engine but it does not start. I checked the flywheel with my finger and it is rotating now without any resistance. is the conrod broken? my 12tz 3 ports is only 2 months old and I have used only for about 8 to 9 times.
#765
Originally Posted by dameetz
Which one is better/faster TZ3 or TZ5? I m going to get one soon and its legal to run outlaw eng at my local track.
