Old 01-02-2006, 08:45 AM   #901
Seisick's Avatar
Originally Posted by BrainTeased
Hi I was just wondering after how many Litres of fuel do you guys use after experiencing bearing leaks.
also did you guys use after run oil?
thanks in advance
10 litres in my case, changed front bearing, no more problem leaking, by the way rear bearing lasts no more than 12-15 litres,
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 01-03-2006, 05:22 AM   #902
BrainTeased's Avatar
Originally Posted by onnetz
as opposed to not?
Yes as opposed to not using after run oil.
and thanks for the input Seisick
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 01-09-2006, 11:21 PM   #903
Default O.S. TZ
Is the O.S. TZ capable of doing well at a large National level event? I have the 5 port, and have been considering the TZ or possibly the Sirio.
Has anyone tried minor modifications?
onthegas is offline   Reply With Quote
Old 01-10-2006, 04:18 AM   #904
jez
jez's Avatar
Apparently JP is doing O.S. TZ motors now. Don't know when its going to be for sale but it was said to be balistic (check the JP engines thread).
jez is offline   Reply With Quote
Old 01-10-2006, 11:07 AM   #905
Rapid Roy's Avatar
Try searching for Motorman's posts. He has been using the TZ to mod and has good things to say about the results.
Rapid Roy is offline   Reply With Quote
Old 01-11-2006, 03:36 AM   #906
Trader Rating: 13 (93%+)
Default broke in my 5 port tz today WOT
hey guys
broke in my engine tonight at wot
was pretty scared at first but then i realised the idea behind it all
the glow plug battery wasnt fully charged so this also gave me the chance to heat cycle as well
during the whole break in process the engine wouldnt get any hotter than about 65-70 degrees celsius
cant wait to tune this engine now at the track
i used josh cyrules method, i just have 2 more tanks to drive around in at the track to tune it to race speed
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 01-14-2006, 03:42 AM   #907
Car Breaker's Avatar
this might been asked before, but can 18tz(p) carburator use onto 12tz?
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 01-14-2006, 10:04 PM   #908
hey guys
how much run time do you guys get from a full tank using the 5 port in a on road car ?
i ask because today i was getting just over 5 minutes to a tank, engine temp was 104 degrees after the race
thanks
Old 01-16-2006, 12:23 PM   #909
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Smile
I was wondering what is some of normal temps you have with this motor? I know mine is 220-240F. Feed back from O.S.12TZ owners is appreicated.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 01-20-2006, 09:45 PM   #910
Motorman's Avatar
Yup I love these things
Ivan that is the normal window I usually see.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 01-21-2006, 12:37 AM   #911
Default tuning problems
hey guys
im having a few problems keeping these engines tuned
i have both the 3 port and now the 5 port
how are your needle settings set ? i mean have you had to screw them in much from standard settings?
im using 16%nitro fuel with 10%oil and an os6 plug
should i be removing one of the shims for the lower percent nitro ?
thank you for any tuning help
i used to have an os tr r spec that never needed so much tuning between race to race
Old 01-21-2006, 10:23 AM   #912
Originally Posted by mrgsr
hey guys
How much fuel do you have through each??? What kind for break procedure did you use??? These motors are just as easy to tune as the old TR's... Check your motors compression, pull the plug out and check it's compression... If it's gone, get a new piston and sleeve set... If compression is ok, and you've checked for air leaks ie... exhaust, fuel tubing, carb leaks ect... If everything is ok, then go back to factory settings on both the high and the low speed needles.. Once the low speed needle is set, leave it alone and just tune the high speed needle... The OS is very easy to tune and holds it's tune very well... Remember, the TZ settings are not like a Sirio or Nova, so if someone tired to tune it like it's a Sirio or Nova, You'll have major problems... Go back to the base factory settings... Put the low speed needle at stock setting as per manuel/OS website and you might have to lean it one or two ticks at the most... Not knowing the temp in your area and the quailty of fuel you're using, it's hard to tune your motor without seeing it... This is just to get you into the ball park... Now, you should be rich still because your high speed needle is at the base/stock setting as well... Just lean the high speed needle one hour/tick at a time to get your settings right while the car is being run on the track and not in the pits... Once the motor is set, you're good to go... If your motor keeps having problems after that... You'll have to take the motor out and take it to your lhs or to someone that can inspect it more closely... As you can see, it's easy to get it right and alot can make it wrong... And without seeing the motor... But this should help get it right... PS... Don't remove any of the shims... Keep everything stock.. Run 20% nitro fuel at least, so go get some new fresh fuel and while you're at it, get some new fresh plugs and fuel tubing as well... Keep that air filter clean too... Goodluck.
RC_Alan
rc_alan is offline   Reply With Quote
Old 01-21-2006, 03:31 PM   #913
RC_Alan thank you heaps for that
i used the josh cyrul break in procedure for both the engines. the 3 port has had about 2 gallons thru it
and the 5 port is still new, break in procedure (10 tanks) then about 1 litre of fuel.
the 5 port has been running temps about 110 degrees celsius
only in one heat someone tuned it and reached 130 degrees but was quickly shut off.
Both engines still have a tight pinch with the glow plug out so the compression is still tight. Here in australia we only use 16%nitro for events so i like to keep running the same fuel all time round. when you say 1 or 2 ticks do u mean 1/8s or full turns ? yesterday after racing i set it back to factory settings and i seam to get the engine going, but i dont know how fast it will be till i see it at the track again this weekend.
the factory settings i have are flush low end needle and 1 3/4 turns on high speed. the mid needle has never been touched.
Old 01-21-2006, 05:45 PM   #914
THOSE TEMPS ARE IN THE BALLPARK. HOW IS IT RUNNING ? YOU SHOULD HAVE PLENTY OF SMOKE AND VERY GOOD POWER. IF YOUR TOP END IS A LITTLE SHORT,LEAN IT 1/8 TURN AND RICHEN YOUR BOTTOM THE SAME AMOUNT. DONT TUNE BY TEMP ONLY THATS THE MISTAKE MOST DO.SOME DAYS 200F IS PERFECT,AND SOMETIMES 260F.IT ALL DEPENDS ON WEATHER.
Ahhh the smell of nitro in the morning!
Brooklyn Hobbies Team Driver
[url]www.brooklynhobbies.com[/url]
Team Trinity
[url]www.teamtrinity.com[/url]
Gary Figueroa
GFIGUEROA is offline   Reply With Quote
Old 01-21-2006, 06:23 PM   #915
Wink
Thanks,
Bisides that the motor runs great.
