OS 12 TzR
#781
Originally Posted by Darth Vader
Guys,
Need some help.
I've got a 5prt TZ with a worn inner bearing. Needs to be replaced coz there's too much freeplay and the crank is rubbing the case.
Any idea how to remove the bearing?
Can I send it back to OS? Anybody here from OS and can give me the South East Asian distributor? Please PM me...
Thanks in advance.
Cheers...
Need some help.
Thanks in advance.
Cheers...
Next, some people use a screw driver, but if you heat it enough, you can take the hot motor out of the vice with a thick rag, and bang it on the bench with the bearing facing downwards (so, bang it as if you were banging on the back plate). This should knock the bearing out and you'll be left with a motor ready to take your new bearing.
Of course, heat up the block in the same fashion to get the new bearing in there too.
I've done this about 3 times to engines in the past and it works everytime. Hope this helps!
#782
Originally Posted by mgreen
Secret, can you get 20% or 30% nitro? That's what I run. I would think that 15% wouldn't be enough; but I could be wrong. At 196F, that motor has not had a chance to move yet. 220F, 230F is OK as long as you see smoke coming out of the pipe while your racing. Also, the manual, for the 3 port, says to use the #6 turbo-plug but it's too hot in Texas for that, So I've been using the HPI #7's and my motor has been performing perfect. So I would think the #7 for a 5 port would be OK. I was in Dubai for awhile. It's just like Texas.
#783
Originally Posted by Aphinity
To get the inner bearing out, or the outer one, you have to use a propane torch. Remove everything from the engine that you can, and clean off any excess dirt or oil off of the outside. Next, put the motor block in a vice holding the two motor mount tabs on the motor so you don't have to touch it. Next, take a propane torch and heat the area around the outside of the inner bearing all the way around. Make sure to get it good and hot. Heating the case will cause the metal to expand and the bearing to be removable.
Problem is, a propane torch isn't exactly something one would find lying around in a common household.
I'd try with the gas stove instead.
Cheers
#785
Originally Posted by Artificial-I
Does anyone have a dyno of this motor vs others. No single magazine reviews.
Thanks.
Thanks.
http://www.rcnitro.com/rn/articles/dt_tzt3.asp
AFM
#786
I managed to get the inner bearing out yesterday.
Heated the crankcase over my gas cooking stove up to about 130C then popped the bearing out with a bearing puller. Took just one pop for it to come out.
Thanks for all the help guys...
Now to find a replacement...
#787
i just bought a conrod from rc-toro.com. I saw they also have the bearings for OS 12 TZ.
#788
I can get SKF or NTN replacement. The question is, should I get with 1-sided metal shield or open bearing?
#789
I have FW-05r and im running 12 TZr 5 port and our local race track is not really big.
the layout of the track is attached.
what is the best exaust i can use ?
#790
Couple of Quick question guys, im deciding on a new motor or two.
How long are these motors lasting (gals)? How is the tuning? Are they finiky with certain pipes? Does anyone have a dyno of this motor vs others. No single magazine reviews.
Thanks.
Thanks.
#791
hi guyz,
can anyone teach me how to break in this engine ( aside from the usual breakin tips).
tnx in advance. . .
tnx in advance. . .
#792
#793
has anyone run the o.s. tz 3 port modified yet if so how did it perform
#794
Originally posted by Mr. Secret_Weapon
try it. its very good
Have any one tried this break in process???
#795
