Old 09-01-2005, 10:48 PM   #721
Rapid Roy's Avatar
Read back a few pages and you will see many comparisons.
Rapid Roy is offline   Reply With Quote
Old 09-05-2005, 01:46 AM   #722
chippy's Avatar
Default Zac tuned TZ 3
Has anyone tried this yet
http://www.kawahara-racing.co.jp/E_index.htm
chippy is offline   Reply With Quote
Old 09-05-2005, 02:01 AM   #723
moot's Avatar
my 5 port is starting to slow down after about 12 litres of 30%.
i was looking at this:
http://www.racefactoryrcp.com/Mspeed.html
moot is offline   Reply With Quote
Old 09-05-2005, 03:24 AM   #724
Regional Moderator
daniz24's Avatar
My friend had tested the ZAC TZ 3 Port yesterday. I must say this engine is a lot better than the standard TZ but needs higher nitro content to get it's maximum power out.
daniz24 is offline   Reply With Quote
Old 09-06-2005, 04:22 PM   #725
freefallmarine's Avatar
The more and more i use this engine the better i like it! This thing screams so high it makes me nervous. but the power is still there at high rpm. Gotta say, this TZ is awsome!!
freefallmarine is offline   Reply With Quote
Old 09-07-2005, 09:16 AM   #726
So i have a TZ 3p and it has been running great, however the track that i run on is small so i have never really streched it legs, so my friend who has a radar gun and i tested it in my mtx3 the other day, When i thought the motor was about to top out RPM it just kept going, needless to say even with my gearing for a very small track the car still hit 56mph, i just couldnt beleave how much more top end there was that i have never used.
ATXPro4 is offline   Reply With Quote
Old 09-07-2005, 03:23 PM   #727
moot's Avatar
do you guys think i need to add shims to run 40% in the 5 port?
Old 09-07-2005, 04:53 PM   #728
Run a P8 plug and see if the plug goes bad. I have friend's that run 40% and there are no problem's at all. You should be alright because i removed the .o1 shim from mine on 30% it power went up, with no problem. The piston top was as shiny as new after 1/2 gallon's.
Old 09-07-2005, 05:41 PM   #729
moot's Avatar
no worries i'll give it a go.
i use the p7 with 30% and stock shimming now.
but i'll try the p8 40% and that will be with the big carby insert and the big shark pipe
Old 09-07-2005, 06:27 PM   #730
Moot let me know when that thing take's off so i can catch it here!!!
Old 09-08-2005, 12:36 AM   #731
I just got a sweet deal on the OS 12TZ 5 port. Anyone run it against the regular 3 port? I ran against the 5 port with my Mugen X12, and I was very impressed with the 5 port. Hopefully I'll get it by next week.
snowboardgeek1 is offline   Reply With Quote
Old 09-08-2005, 05:32 AM   #732
Hello from France,
a nice version from a French tuner....
romuald31 is offline   Reply With Quote
Old 09-10-2005, 10:16 PM   #733
Picked up a vantage carbon pipe. Ill let you know how it work's out on the 3 port this week.
Old 09-14-2005, 03:00 AM   #734
moot's Avatar
how long is this motor going to last? i'm trying to kill it now and it wont let go
i run 30% with the outlaw shark pipe and its lean as hell (almost cutting out ) i put in the smallest gearing and just reved the crap out of it over 15 netball courts. it hits full rpm/top speed over 2 of the side by side i ran 4 tanks through it like that and it only gets stronger after 16 litres.still idles nice and has heaps of torque
i would have gone through 6 jp's by now.
Old 09-14-2005, 07:14 AM   #735
And even when i does finally go out on you its gonig to be less than $70.00 USD to get a new Piston, sleeve and conrod.
