Old 09-14-2005, 05:16 PM   #736
Trader Rating: 44 (100%+)
well .. alternatively, u can have the sleeve resized (by someone like Osrocket) to extend the life of the engine.
so you only have to pay for resizing cost + new conrod to give the engine a new lease of life.
that's what i've done with my .21 OS engine. cheaper option
wyl03 is offline   Reply With Quote
Old 09-14-2005, 11:01 PM   #737
I agree but u have to make sure that you dont pinch it to much, its a good way to break a con rod. But yea its an even cheeper way to get new life out of it. What it all comes down to is that when these motors finally do wear out they will be cheap and easy to get up and running again.
ATXPro4 is offline   Reply With Quote
Old 09-14-2005, 11:55 PM   #738
Hi there!
Im just wondering why there are different materials for engine head shims.
My O.S. came with a 0,1mm copper shim and a 0,2mm brass shim.
My Nova got an aluminium one.
Why different materials?
I assume the copper shim is meant to go directly on top of the sleeve because copper seals very well. But why aluminium and brass?
Many thanks in advance!
fulcrum2 is offline   Reply With Quote
Old 09-15-2005, 07:10 AM   #739
my guess would be that its so you call tell what thickness the shims are wuthout having to get out a set of calipers. Just a guess though
Old 09-15-2005, 09:35 AM   #740
Aphinity's Avatar
Send a message via ICQ to Aphinity Send a message via AIM to Aphinity Send a message via Yahoo to Aphinity Send a message via Skype™ to Aphinity
Historically, this is exactly why they do it. Different companies might use different materials to represent different sizes. In general, always use one brand of head shims, and you won't have this issue.
Aphinity is offline   Reply With Quote
Old 09-18-2005, 07:02 PM   #741
Trader Rating: 14 (100%+)
Any of you guys with the .12tz notice any wear to the backplate and corresponding side of the conrod? I know that has been a problem with the .18tz's
thunderbt3 is offline   Reply With Quote
Old 09-19-2005, 06:11 PM   #742
Anyone knows where I can buy parts for TZ 5 ports? crank/piston/connecting rod? thx.
silverM3 is offline   Reply With Quote
Old 09-23-2005, 06:50 PM   #743
dnitro's Avatar
I had the 5port for about 2 months and it just started to bust my glow plug left and right. I went thru 4 plugs in 20 minutes. When I opened up the engine, I noticed that the piston had a hug crack and a small chunk missing, probably disintegrated. There were small metal shavings inside the engine that was killing my plug. I returned it to OS. They said it was not a manufacturing defect but they replaced it with a new engine anyway. I was really impressed with their customer service. The turn around time was only 2 weeks.
TM G4S
IDM Evo3
dnitro is offline   Reply With Quote
Old 09-23-2005, 09:15 PM   #744
thefuzzclub's Avatar
Default os tz 5 port
i got an os tz 5port from a good friend of mine but i don't have the manual, just want to ask what is the initial low and high needle settings when breaking in.
thefuzzclub is offline   Reply With Quote
Old 09-24-2005, 12:29 PM   #745
jeff1's Avatar
You can download the instruction set in OS site
http://www.os-engines.co.jp/tz/engli...12tz(p)_me.pdf
For HSN close all the needle and open 1 turn 3/4 for low speed setting just flush the screw with the ball link body
jeff1 is offline   Reply With Quote
Old 09-25-2005, 07:19 PM   #746
many thanks for your help..
Old 09-27-2005, 02:12 AM   #747
Shop Owner
We finally get some 12 TZ 3/5 ports parts in stock. Please go to http://www.rc-toro.com/index.php/cPa...f8b21c53d584dc
toro_man is offline   Reply With Quote
Old 09-27-2005, 07:39 PM   #748
yodace's Avatar
R/C Tech Charter Subscriber
Which O.S TZ engine/ part number are u guys using in the AD2?
yodace is offline   Reply With Quote
Old 09-28-2005, 02:23 AM   #749
AndyT 's Avatar
Detonation? what % nitro were you running? shims?
AndyT  is offline   Reply With Quote
Old 10-07-2005, 03:26 AM   #750
Default os tz 5port
the 5port sure has a wide carb. anyone tried running the engine without restrictor? will it produce more punch? speed?
