Old 12-17-2005, 11:08 AM   #886
Originally Posted by mrgsr
hey guys
i had a pretty bad day with the os tz today
it would not at all hold its tune, and was so gutless the pull starts were keeping up with me.
i came home and stripped the engine to see whats going on, their doesnt seam to be any blow by on the piston but it is all scratched around the round edge.. i had one of the more experienced engine tuners at th track trying to keep it tuned but no luck...
the compression feels kinda tight but the flywheel is able to be turned around
it was running a bit on the leaner side so i guess there was no lubricating happening.. what should i do ? replace piston/sleeve ? engine has had about 2 gallons
If you see scratches on the piston, you're not cleaning your air filter... Dirt is what scratches the piston... It sounds to me that you've been running your motor to lean for to long and now your motors compression is gone... OS. has a 2 year warrenty on it's motors... They will correct any problems that's there's fault... End users that damage or miss use there products ie. over leaning a motor, continue to run the engine that is out of tune and not cleaning/changing to a fresh air filter are kinda on there own... Not trying to bash you... It just seems that you didn't take good care of $200.00 dollar investment. You can always give OS a call or email them... Good luck
RC_Alan
rc_alan is offline   Reply With Quote
Old 12-17-2005, 06:59 PM   #887
Trader Rating: 13 (93%+)
that was a brand new and oiled air filter
i take great care of my engine always monitoring temps and glow plug condition
2 weekends ago it was one of the qucikest cars on the track and still running on the richer side. im pretty sure these tuning problems are coming from the small hole in the boittom of the pipe, i did have this hole kinda sealed however there was still heaps of oil residue around the hole
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 12-18-2005, 12:14 AM   #888
Default oil percentage ??
what oil blend do you guys recommend for this engine ?
currently i was using 16%nitro with 8% oil (4%syn 4%cast)
i was thinking of going up to a 10/12% oil based
John
Old 12-18-2005, 06:19 PM   #889
Darth Vader's Avatar
mgrsr,
If you have a clean air filter on and there is no debris in your engine, then don't worry about the scratches. I have some around my piston also.
Your problem could be due to the hole in your pipe. Affects your idling and tuning.
I also suffered a similar problem with my TZ a couple of months back. The inner bearing was worn and there was too much freeplay. Crank was rubbing the case. Leaned it quite a bit but engine was still sluggish. And it would cut off randomly on the track. There's also a rattling noise at idle. If you face these symptoms, maybe your inner bearing is gone too...
Darth Vader is offline   Reply With Quote
Old 12-22-2005, 02:11 PM   #890
gijoe64's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Tabushi
Anyone can give me advice of a good pipe for the OS .12 TZ 3 port Turbo ? ... i was thinking about the OS 1040 but its comes up to US$ 104 !!
thanks in advance,
Pat
Try the Skyline pipe 80.00$
gijoe64 is offline   Reply With Quote
Old 12-22-2005, 10:41 PM   #891
I bought my 1040 (header + pipe) at rc-toro. I think with shipping it is only $95. I also had skyline vr12, but i like 1040 better. In general, it is better to use engine and pipe from the same company.
silverM3 is offline   Reply With Quote
Old 12-25-2005, 07:30 AM   #892
caggers's Avatar
Could someone outline the best method for finding air leaks in engine/fuel line/tank. My TZ is running very hot even though its running under rich settings, i know there are many factors which would contribute to high running temps however I think an air leak is the most probable cause in this case.
I am using p6 plug with 15% nitro and 15% synthetic/castor mix.
caggers is offline   Reply With Quote
Old 12-25-2005, 09:31 PM   #893
FIRST OF ALL WHAT DO YOU CONSIDER HOT? TO CHECK YOUR FUEL SYSTEM FOR LEAKS TAKE OUT TANK AND FUEL TUBING PUT TANK UNDER WATER BUT KEEP VENT AND FEED SIDE ENDS OF TUBING OUT OF WATER SQUEZE CLOSED VENT END AND BLOW INTO OTHER IF YOU HAVE LEAK YOU WILL SEE BUBBLES COME OUT .AS FOR THE ENGINE IT IS MUCH EASIER TO JUST SEAL ENGINE I SEAL ALL MY MOTORS EVEN WHEN THEY ARE NEW.
Ahhh the smell of nitro in the morning!
Brooklyn Hobbies Team Driver
[url]www.brooklynhobbies.com[/url]
Team Trinity
[url]www.teamtrinity.com[/url]
Gary Figueroa
GFIGUEROA is offline   Reply With Quote
Old 12-25-2005, 10:00 PM   #894
SpeedBump57's Avatar
Caggers a couple of things.
1. do what MANINTHEMUGEN has sugested. (man that is a long name
2. you might want to think about going to 20% as it will run a little cooler.
3. Some times running too rich will cause an engine to run too hot as well.
SpeedBump57 is offline   Reply With Quote
Old 12-25-2005, 10:49 PM   #895
AndyT 's Avatar
Another fast way to check for an air leak is to remove the air filter whilst the engine is idling and cover the air inlet with your finger.......if the engine doesnt die instantly theres an air leak somewhere.
AndyT  is offline   Reply With Quote
Old 12-26-2005, 04:40 AM   #896
caggers's Avatar
Thanks for the help.
Old 12-30-2005, 06:19 AM   #897
Default bearing
has anybody tried finding a ceramic rear case bearing for the os ? any luck?
isuzuguy is offline   Reply With Quote
Old 12-30-2005, 09:54 AM   #898
Give this link a try... You should be able to find them and order them as well... http://www.bocabearings.com/main1.as...earchkit&cat=2
Front and rear bearings for about $75.00
RC_Alan
Old 01-01-2006, 03:03 AM   #899
BrainTeased's Avatar
Hi I was just wondering after how many Litres of fuel do you guys use after experiencing bearing leaks.
also did you guys use after run oil?
thanks in advance
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 01-01-2006, 07:02 AM   #900
onnetz's Avatar
thanks in advance
as opposed to not?
onnetz is offline   Reply With Quote
