Old 10-17-2005, 02:37 AM   #766
Team-RTR's Avatar
for you people with the ZAC racing TZ, what pipe suits these engines?
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 10-18-2005, 11:47 PM   #767
Secret_weapon's Avatar
Hi
I have a new 5 port TZ i raced guy in my local track he has fw-05rr , so do i.
I am using the same gear ratio but he seems to pass me at the bottom end.
I think its the exaust because im using kyosho exaust.
Any suggestions of a good pipe.
Secret_weapon is offline   Reply With Quote
Old 10-18-2005, 11:59 PM   #768
i also have a 5 port. I am using OS 1040. I tried many different pipes:novarossi52606, skyline vr12, and sts outlaw. I like 1040 the best.
silverM3 is offline   Reply With Quote
Old 10-19-2005, 07:45 PM   #769
I'm running a .12TZ 5port in my GSX sprint car with a Dynamite dual chamber competition pipe. It really seems right for my application.
MauriceG is offline   Reply With Quote
Old 10-19-2005, 07:59 PM   #770
JLock's Avatar
Everyone is talking about the OS 12tz 5-port. Let me tell you that the 3-port is nothing to take lightly. I switched to it after the two days of qualifying for the Paris Memorial Race and ran it in my main. My weapon of choice was the Mugen MTX-3. Man, I should have switched out motors sooner. The motor had more than enough low-end torque and enough top-end to hold most of the higher-end Nova and Sirio motors at bay. After running a 40 minute B-main, it came off the track at a cool 196 degrees!! And, I still could have squeezed some more power out of it. Word of note: the motor was box stock with no modifications!! I have always been a fan of OS motors but now I am sold on this one over the Nova, Picco, and Sirio-based motors. With the piston and sleeve around $70, rod for around $20, and power to hang with the big-dog motors, looks like OS will be the way to go for me.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 10-19-2005, 10:26 PM   #771
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Originally Posted by Secret_weapon
Hi
There are other factors that have to be taken into consideration like: Engine Setting and Clutch Setting. But how are engines running today, I believe the 3-ports are running faster than the 5-ports. Also, try using the VR-12 Pipe. It brings out the power in almost any motor I have used/tried.
Riketsu is offline   Reply With Quote
Old 10-21-2005, 02:00 AM   #772
196 C or 196 F, because 196 C is too much.
Old 10-21-2005, 09:42 AM   #773
Riketsu's Avatar
Its probably 196F, cuz if it was 196C he probably wouldve started to make the proper funeral preparings for the engine.
Old 10-21-2005, 12:17 PM   #774
JLock's Avatar
That is 196F. I don't know what that translates into as far as celsius.
Texas 5
Old 10-23-2005, 04:27 AM   #775
I'm running 15 % nitro and 18% lubrication, and im using p7 medium plug
I had the temprature reaching 124 C( rich mixture). Is it fine or not ? and what is the perfect temprature in running this TZr 5 port engine.
Old 10-23-2005, 05:39 AM   #776
Team-RTR's Avatar
im pretty sure thats too hot, 120c is the temperature u want your motor to be running at after being tuned for max performance. try running a fuel with less oil (about 10%) and go from there.
Old 10-23-2005, 08:21 AM   #777
Ok, but the engine manual say not to use with less than 18% of lubrication.
Old 10-23-2005, 08:30 AM   #778
Slotmachine's Avatar
Send a message via MSN to Slotmachine
I use White Lightning With 8% oil, no problems!
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 10-23-2005, 07:13 PM   #779
Darth Vader's Avatar
Default Worn inner bearing
Guys,
Need some help.
I've got a 5prt TZ with a worn inner bearing. Needs to be replaced coz there's too much freeplay and the crank is rubbing the case.
Any idea how to remove the bearing?
Can I send it back to OS? Anybody here from OS and can give me the South East Asian distributor? Please PM me...
Thanks in advance.
Cheers...
Darth Vader is offline   Reply With Quote
Old 10-24-2005, 12:31 AM   #780
Smile
Secret, can you get 20% or 30% nitro? That's what I run. I would think that 15% wouldn't be enough; but I could be wrong. At 196F, that motor has not had a chance to move yet. 220F, 230F is OK as long as you see smoke coming out of the pipe while your racing. Also, the manual, for the 3 port, says to use the #6 turbo-plug but it's too hot in Texas for that, So I've been using the HPI #7's and my motor has been performing perfect. So I would think the #7 for a 5 port would be OK. I was in Dubai for awhile. It's just like Texas.
mgreen is offline   Reply With Quote
