Ninja Engine by GRP
Old 07-14-2007 | 09:28 PM
  #1006
cdelong's Avatar
let's see.... it dies when it's hot right? runs fine when it's cold?
pinch is gone if so.
cdelong is offline
Old 07-14-2007 | 09:53 PM
  #1007
wallyedmonds's Avatar
sounds like it.
wallyedmonds is offline
Old 07-14-2007 | 10:01 PM
  #1008
Roger's Avatar
cdelong is correct.
The ninja plugs are tapered more than novarossi / O.S. glow plugs. That means when you use a different plug other than the ninja plug, you just opened up the button a little more than it was made for; possibly causing an airleak.
Roger is offline
Old 07-14-2007 | 10:46 PM
  #1009
Originally Posted by Roger
cdelong is correct.
i noticed that the treads are different,
a sirio is about the same.
but the best plug is the ninja's,ya ya i know some ppl say umm well stuff but it really is true,the motor just runs better.
Old 07-15-2007 | 11:16 PM
  #1010
chuckinator's Avatar
Thanks for all the info guys. I guess that we will have to try to get some Ninja plugs into our LHS. What # are you recomending? Its not that the pinch is gone because it will die even before it gets up to temp. It really doesnt matter if it is hot or cold, it just dies.
chuckinator is offline
Old 07-15-2007 | 11:47 PM
  #1011
cdelong's Avatar
Is there any resistance at TDC when you remove the plug? Does it roll over easily with the plug in?
Is the piston dome tan, brown or sanded looking?
cdelong is offline
Old 07-16-2007 | 04:12 AM
  #1012
M7H's Avatar
M7H
Throw away all your NovaRossi experience with these engines guy's..... the combustion chamer shape/depth and button depth in the cylinder is vastly different from Nova engines.
I normally roll over and get 0.028" clearance on a Nova with 0.7mm of shims. With 0.55mm of shims on the Ninja, you won't even touch 0.050" solder to check the clearance. Just go with the 0.55mm of shimming recommended by Mike for the initial break-in and then drop it by 0.1mm after it loosens up.
0.028" is 0.71mm, so the Novarossi combustion chamber depth is the same as the measurement from piston at TDC, to top of liner.
0.050" is 1.27mm!!!, which seems a lot of head clearance to me....
According to your statement, you even have a head clearance of atleast 0.72mm (1.27-0.55), without any shims installed.
Is this correct?
M7H is offline
Old 07-16-2007 | 06:12 AM
  #1013
Nitro$junkie's Avatar
dosent this look tasty.....3 meets old
Attached Thumbnails Ninja Engine by GRP-dsc00196.jpg   Ninja Engine by GRP-dsc00195.jpg   Ninja Engine by GRP-dsc00194.jpg
Nitro$junkie is offline
Old 07-16-2007 | 06:25 AM
  #1014
Wild Tiger's Avatar
Shit dude, what the hell happened there ??
Wild Tiger is offline
Old 07-16-2007 | 06:30 AM
  #1015
my guess some thing got sucked into the engine a bit of the sleeve is missing off the top of one of the ports to not happy a good thing is new P/S is cheap but still
Old 07-16-2007 | 06:52 AM
  #1016
Wild Tiger's Avatar
A bit of the sleeve is missing?
Yeah but still, you don't need that kind of crap happening on it's 3rd meet!
I feel for you !!
Old 07-16-2007 | 07:02 AM
  #1017
M7H's Avatar
M7H
My guess.
Your liner broke between the intake ports, this made the damage.....
The strange thing though, I've seen this before, but always on the exhaust side, not the intake......
Or is your liner still intact?
M7H is offline
Old 07-16-2007 | 08:12 AM
  #1018
Corse-R's Avatar
My idea goes thru the path that M7H suggested, but... wanted to teardown an R01 just to see where you got the damage.
Time for a complete teardown of the engine and a very scrupulous inspection of the bearings, my idea is that some kind of cr*p went thru the sleeve and got trapped by the smaller square boost ports you have at the front sides of the sleeve, disassemble completelly and inspect for damage on the port that runs over that area, much probably you'll find something.
Could be a small part of bearing, remove the main bearing and inspect it.
That hurts!. Look at the first photo and you could see what seems a hole thru the piston skirt... amazing.
More details about the carnage? Fuel? Operating temp...
Corse-R is offline
Old 07-16-2007 | 08:27 AM
  #1019
that excatly what happend little bit of sleeve missing is right at the top of this port on the left side
fuel 25% oil 10% temp 110-115C*
Old 07-16-2007 | 08:31 AM
  #1020
no hole just a little deeper in that one spot
