Ninja Engine by GRP
#976
Hey Layman ~
3 words for you Maintance, maintance, maintance!
If you want people to help you here, you need to tell them everything. Maybe like your header gaskets were leaking really bad, stripped 2nd gear in the last 3 mains that you ran.I told you about the gaskets but you still ran it? You also tryed finishing the mains with a stripped 2nd gear, now that can't be good for a rod?
Don't start bashing a company and there motor because of your stupidity and lack of maintance! If you had ran any other motor company like what you just did, the results would have been the same!
Loose carb? Any ONE of these 3 things would have caused your motor to go lean, but you had All 3!!! ROOKIE!!!
Harry
Harry
#977
Hey Layman ~
Harry
Harry
#978
Also Harry,
You told me to send the engines to Mugen & I did. Why would you tell me to send the engines to Mugen if they werent going to help me. Also, I just found out that there is no warranty for these engines. Atleast thats what it says on the CD-rom that comes with the engines. So why are you talking like this to me. I was hoping that they would help me since you helped me with a sponsorship.
#980
this i think is a cool pipe.
and just to say about the carb problem some have, my clamp bolt clamps very nice,but i did notice that the carb needs to be sealed to prevent leaking, so the motor wont run lean or erotic.
come to think of it all my motors iv run the o rings kinda sucked
sirio
novarossi
os
sirio
novarossi
os
#981
Hi guys, I need some help here.Own a R01 and I am confused about the head clearance.My question is,should the shim thickness in total to be 0.6mm or shim it so that the clearance at 0.6mm when TDC.
Running 25% Tornado Fuel with Ninja Pipe. Currently running 0.4mm shim thickness and have a head clearance of 0.95mm.I used a solder lead and turn the flywheel over to get the 0.95mm clearance after measuring the squeeze solder lead.Am I doing it right?
#982
on a short track you can get away with the stock shimming with 25 but on a big track you have to add a shim.
#983
Thanks for the info.The problem is when I buy the engine it came without any extra shim.There is only one 0.1mm copper shim already install on the engine.May I know the thickness of the extra shim.
#986
Run the engine with an head clearance between 0.6 - 0.7mm
Measuring with solder is a possibility, I always do it this way. (if possible due to the engine's pinch)
Take out your plug, rotate the flywheel until your piston is in TDC.
Unscrew the engines head and burnroom.
Measure the distance between top of piston and top of liner.
Make the same measurement for your burnroom (without any shim)
Now you know the headclearance your engine has, without any shims installed.
(should be 0.55mm, concluded from your story)
#987
When talking about shims, it is always reffered to the total amount of head clearance.
0.95 is to much, your engine probably doesn't have a lot of bottom power.....
Will go back and reshim my engine and see how it perform.Do you think its because of the engine head clearance at 0.95mm cause the con rod to fail in less than 1 gallon of fuel as I have posted it on this forum before.
#988
About the conrod failure, no I don't think so, because normally you would see conrod failures if the head clearance is too low.... I think you just had bad luck with the conrod....
But maybe because of the big head clearance you needed to put in quite a hot plug to keep the engine running, which on his turn might do some harm... don't know....
I don't know the Ninja engine in detail, but 0.55mm head clearance without any shims installed seems a bit high to me...
It is possible offcourse, but most engines I've run, Nova based, Picco based, have a headclearance of somewhere between -0.5 to 0.25 mm (with -0.5 I mean that without any shim, the piston hits the headbutton)
#989
you want head clearance from .46 to .57 thats 18thousance to 22 thousands of an in.
but i have run a motor with lower clearance and got better low end but you do risk detonation, and the top of the piston looking like the moon,pitting,
after 1G run in did any 1 change the con rod, i always do when i can get one.
#990
Dear all,
Wanted to know whether or not anyone has the full parts listing for the Ninja R01.
Looking for all the parts required for a full P+S+R set for this engine including wrist pins etc. and all parts numbers. Could anyone help out? I am unable to find the required cat. #s anywhere where I am ATM.
Thanks in advance.
Thanks in advance.
