PICCO .21 BOOST
Old 07-30-2011 | 03:21 AM
  #241
If so that's good news - that the Jammin/Picco P7 line will continue in some form, with the Jammin apparently being discontinued...
Herrsavage is offline
Old 07-30-2011 | 04:04 AM
  #242
Ambros303's Avatar
Originally Posted by blade954
Looks like to me that the New P-6 is the Jammin JPX.21 but with a few tweaks here and there.....
Afaik the Jammin JPX = the good ole Picco P7-R evo3 (5+2 port). Powerfull engine with a lot of bottom end.
That same P7-R is now reincarnated as the Boost .21 5TR
The P6 seems to be a new sleeve design for Picco
Ambros303 is offline
Old 08-07-2011 | 04:24 AM
  #243
blade954's Avatar
Decided to try the new BOOST carby on the Boost 3TR very well made and long needles which is different to the carby that comes with the engine.... Plus it moves the idle to the top of the carby when on the engine which makes it easier to get to....If it makes a noticeable improvement I'll drop one on the EDO in the Truggy.
blade954 is offline
Old 08-07-2011 | 04:48 AM
  #244
blade954's Avatar
And for the record here is the standard carby
blade954 is offline
Old 08-07-2011 | 05:09 AM
  #245
Ambros303's Avatar
Nice carb, seems to be good quality
That full alu carb should solve all the problems Picco had before with the composite/alu carb and airleaks at the seams (transition alu to composite). Altho, i think the latest gen composite carbs were pretty solid & airleak free aswell.
Old 08-07-2011 | 05:19 AM
  #246
blade954's Avatar
Yes i must say the new composite carby is a good performer yet to run the alloy carby hope to next weekend if the rain holds out ... the above composite carby has had well over 20ltrs through it with out 1 problem what so ever, The newer Piccos are very well made......
blade954 is offline
Old 10-02-2011 | 06:49 AM
  #247
Folks,
Messed up with my needles and wish to start clean
can someone advise me stock settings for all three needles for this engine? Thanks,
lost_odeassy is offline
Old 10-03-2011 | 06:36 AM
  #248
Originally Posted by lost_odeassy
Folks,
Can really use some help here
Old 10-07-2011 | 03:04 PM
  #249
What is the average temperature of this engine
today mine was at 230 to 240 at ideal and 260 plus during running.
Do think it was on high end since I have not cleaned engine from inside for 2 - 3 weeks now? or was that normal
Old 10-08-2011 | 03:45 PM
  #250
blade954's Avatar
Average temp will vary for every Picco Boost out there, Fuel, Plug, Altitude, Tune on the engine, Me Personally don't even temp engines as i tune on Smoke, sound, feel on the trigger finger. Even what brand car you run it in will vary the temp. If it runs great on the track and say after a 40+min AMain and comes back up the shoot and drops to a perfect idle to me the temp reading is spot on... I see so many people at the races coming in and tuning a engine with a temp gun and hearing "it should run at such and such a temp"...
If i was to give an Average temp i would say 100 to 120 Degree Celsius...
Our little Picco Boost is on its way to 25ltrs and with a new rod @ 20ltr mark still has incredible pop on the flywheel, I like to pull apart the engine every 10 or so liters and just clean the excess carbon off and give the internals the once over....
blade954 is offline
Old 10-10-2011 | 01:14 AM
  #251
Thanks for advise, do you mind visiting following thread where i have posted pictures of my engine and advise how do you see the condition of it?
I am wondering if my needles are out or is engine losing, I am newbie.
http://www.rctech.net/forum/offroad-...my-engine.html
Old 10-10-2011 | 07:19 AM
  #252
Marcus Falconie's Avatar
It looks like the new REDS engine is a Picco I want one
http://www.neobuggy.net/modules/news...?storyid=10983
Marcus Falconie is offline
Old 10-16-2011 | 07:53 AM
  #253
blade954's Avatar
We ran the Picco boost again today at a practice session, The new Boost alloy carby is a must it makes tuning the Picco like the old OS VZB engines.....and improves run time we were getting 9:45 to 10:22 all practice.... The lad really likes this engine....Also for a question asked earlier in the thread about temp this boost ran like a champ today in 35deg c heat (typical day here in Perth)the Boost ran at around 120deg c and like the video shows it was not high idling or anything when it came up the shoot...
In the video i put down it was a Picco 2047 pipe its a Picco 2046 with the short header not the long...
+ YouTube Video
blade954 is offline
Old 10-26-2011 | 03:00 AM
  #254
blade954's Avatar
Taken from NeoBuggy......
Picco recently put together a private test meeting at the track in Asti, Italy – venue of the successful BittyDesign race & owned by former Italian international soccer star Diego Fuser who kindly allowed the team a couple of days of intensive testing. On hand at the 2012 engine test were factory driver Jorn Neumann, Durango designer & Jorn’s mechanic Gerd Strenge & Picco chief Alberto Picco.
The new 2012 spec Boost engine comes with a multi exhaust system to ensure top of the line performance throughout the engine’s upper RPM band. With a 5 port design the engine performs exceptionally well at the bottom end – a characteristic crucial to handle today’s track designs with short sharp blasts followed by jumps.
http://vimeo.com/31098713
blade954 is offline
Old 10-27-2011 | 04:51 AM
  #255
blade954's Avatar
Can any one make out the Picco pipe on The engine looks like a Picco 2033 the onroad pipe, And looks like the new 12 spec has the boost carby on it with the long needles.
blade954 is offline
