Like Tree352Likes
NOVAROSSI Engine thread....
Old 02-08-2019 | 02:14 PM
  #10126
The BX3 is a short stroke 3-port engine with a 13mm crank. It’s basically a 3-port version of the old BX21 series which came in 3, 5, & 7 port versions with and without the boost chamber.
RCTecher12 is offline
Old 02-11-2019 | 08:29 AM
  #10127
I have my flame suit on, no pun intended here. Opening the floodgates of fuel.
What are we running in terms of fuel on the .21 off road engines?
sebtarta is offline
Old 02-11-2019 | 08:59 AM
  #10128
kgombe's Avatar
i have ran 3 race fuels in my time, Byron’s was always my go to fuel, but hard to get and expensive here in Canada,
Vp was good to me as well, I loved it, I decided to try Nitro pro last season and will continue to do so, great fuel, and all around performance from cooling to ease of tune and run times.
thise are the fuels that I have used, all with 30% nitro 9 or 11% oil.. mainly in Nova, or nova based motors.
kgombe is offline
Old 02-11-2019 | 03:43 PM
  #10129
Default Changing the screws
Sorry didn’t really go through the entire thread but was wondering if anybody has ever changed the Straight slot screws in the novarossi to say Allen head screws? And if so what kind worked for you?
racelukatic is offline
Old 02-12-2019 | 01:29 PM
  #10130
HaulinBass's Avatar
If you must
https://www.tonysscrews.com/product.sc?productId=209
HaulinBass is offline
Old 02-12-2019 | 01:47 PM
  #10131
Roelof's Avatar
https://hobbyking.com/en_us/m3-5-x-1...___store=en_us
Roelof is offline
Old 02-13-2019 | 10:58 AM
  #10132
Hello, I have a little doubt.
The Novarossi Elite 5 OFF is a good engine to do only club races with friends at the weekend.
In terms of low, medium and high range is good engine?
In general terms the difference and a lot in relation to your older brother P5XLT, power and fuel consumption?
Pedro Jesus is offline
Old 02-14-2019 | 11:08 PM
  #10133
am
The Elite 5 is a very very good engine. I have raced it here and palced it top 5 at our Norwegian cup. That is slightly modified tough. I have sold 10 of theese engines and evryone is very satisfied with this engine, modified or stock. Get the 41001 or 41005 header and the 2096 pipe. Maybe the new Hipexmade pipe is better, but i have not tested it. 41001/05 and 2096 is a well provencombo on this engine.
am is offline
Old 02-15-2019 | 12:31 AM
  #10134
In terms of price even here in Portugal is a very low price.
And because a lot of people like the engine and say it's good, I always like to hear other opinions, but from what I see it's a good buy.
And a safe bet.
Only Engine costs € 140
Old 02-16-2019 | 07:42 PM
  #10135
1evo RRR Driver's Avatar
Has anyone been running the MEPHISTO with any other pipe other than the 2135? If so what are your findings? I was told by a fellow racer who spoke with the guy from NOVADIRECT...... he said the motor can be run with other pipes , but it was designed to use 2135. For max runtime
Pedro Jesus likes this.
1evo RRR Driver is offline
Old 02-17-2019 | 08:17 PM
  #10136
Would the Mantra be a good choice for a 1/8 truggy?
cornonthecob is offline
Old 02-18-2019 | 02:41 AM
  #10137
roblupo's Avatar
I know some guys have tested the OS pies with it because its a square stroke engine, and the performance was not there. I personally have run and tested the 2135 with the 41021 header and its a great combo. Same with the 9901/41021
roblupo is offline
Old 02-20-2019 | 06:59 PM
  #10138
Lots of good info on here . Just bought a Roma using a dynamite 053. I know its not the best pipe but it’s what I could afford. Anything is better than the stock losi pipe tho. I’m very new to nitro and just want to break this in right. I have ran 2 tanks at idle through it. Temps only at 160. The thing is spitting fuel out the exhaust like no other but novarossi says don’t touch the needles till after 10 tanks . It’s like 10 degrees f outside and inside the building I’d say its about 48 - 55 degrees f on a “warm” day but trust me its been colder in there. Should I lean the hsn a bit? Change plugs? For some reason I’m scared to touch the needles and mess it up.
Thats Bats is offline
Old 02-22-2019 | 06:02 AM
  #10139
I think people should read the Novarossi manual more carefully - not only about the break-in process, but also the fuel composition they recommend. If you run an oilier fuel for break-in, there is no issue in running the needle a little leaner (low speed) to get enough heat built up.
http://www.novarossi.it/2012/images/...uk-general.pdf
Old 02-22-2019 | 01:07 PM
  #10140
HaulinBass's Avatar
novarossi manual? lol the one page of broken english?
nova breaks motors in running them 32000-36000 rpm for 20-22 minutes at temp, not my first choice but its certainly a looooong way from idling.
The tessmann method IMO is the best way to break in, I have yet to try ebis/oil bath motors but ive tried just about every other and it seems they all sacrifice longevity to get the motor ready to race sooner. cant say ive ever idled more than a tank on the box though
