Like Tree352Likes
NOVAROSSI Engine thread....
Old 03-30-2017 | 06:01 PM
  #9436
Taylor8Repair's Avatar
Hello
Taylor8Repair is offline
Old 03-31-2017 | 10:43 AM
  #9437
Default novarossi BX21
Looking for info on this engine Novarossi SBK01 bx21. It has what looks to series numbers engraved on the side 1000 111 And the crank and sleeve appear to be modified.
Anyone know what they mean?
Old 04-13-2017 | 03:33 PM
  #9438
HaulinBass's Avatar
anyone run the new cto plugs yet?
HaulinBass is offline
Old 04-13-2017 | 04:26 PM
  #9439
Maybe done by the legend himseld, Ron Paris original modified? Can't remember if he actually placed his name on the side or not....that engine is surely back in the days when he was around.
Neesh is offline
Old 04-13-2017 | 05:34 PM
  #9440
beidle99's Avatar
I had REX SBK01 as my first 1/8 buggy engine. It was a beast! If i remember correctly it was a square stroke, 5 port. Pretty good all around engine. It would be right with the RB and Sirio engines of the time.
As far as Paris modding it, quite possible but I think Ron passed away in 2001. So it depends on the year. I had one of his .12 touring car engines. That thing had a mid-range kick that you thought a single speed touring car had a 2 speed in it.
beidle99 is offline
Old 04-14-2017 | 04:18 PM
  #9441
The sbk is a short stroke. Lots of bottom end but not the best fuel economy. I don't remember many people pitting longer than 6:30-7 minutes with one. The p5 basically replaced it.
windellmc is offline
Old 04-15-2017 | 02:24 PM
  #9442
Novarossi engine Heater 14.8v IBProstart
kyosho28 is offline
Old 04-17-2017 | 03:47 AM
  #9443
maddog9's Avatar
Is it possible for the carb needles or most likely the o-rings to wear put on a motor? I have a mito 4 and it seemed no matter what tuning we attempted it just kept high revving. We put an older 2 needle carb like the bonito carb and the motor runs great.
maddog9 is offline
Old 04-17-2017 | 08:38 AM
  #9444
You could have a bad o-ring on one of the needles. Do you often turn the needles all the way in and then back out some number of turns?
Old 04-17-2017 | 08:57 AM
  #9445
maddog9's Avatar
Not usually maybe a couple hours at time.
maddog9 is offline
Old 04-22-2017 | 09:35 AM
  #9446
houston's Avatar
Yes the orings can dry out and not seal anymore
Did you get your issue figured out ?
Lmk if i can help ya out
houston is offline
Old 04-24-2017 | 04:09 AM
  #9447
DGP
AMain are out of sock of the P5 Piston/liner set. Where else can I get one at a fair price that isn't $50.00 freight like novarossi direct.
Shipping to New Zealand.
Cheers
DGP is offline
Old 04-24-2017 | 03:47 PM
  #9448
keithw11's Avatar
absolute hobbz
keithw11 is offline
Old 04-24-2017 | 10:53 PM
  #9449
omarwashington's Avatar
I just got a mito 4 pre broken. Says to run 7 to 8 tanks till race ready, is there anything specific that I need to to during this process? Also can someone tell me how to operate the medium needle. This is my first engine that uses the medium needle
omarwashington is offline
Old 04-24-2017 | 11:38 PM
  #9450
Hello All,
Looking for a recommendation.
I have an HPI savage with extended chassis. I'm considering picking up the Novarorassi 28-8 Pull start engine.
Can you guys recommend a manifold and exhaust to go with this engine?
Also, any gearing and clutch recommendation would be appreciated as well. I do a lot of bashing, but would like something with a good balance of speed and power. I don't care for wheelies.
ohhh my is offline
