Like Tree352Likes
NOVAROSSI Engine thread....
Old 06-08-2021 | 07:56 AM
  #10936
1/8 IC Fan's Avatar
Originally Posted by cucan
Yes and it works in my case.......
... really, pics or it didnt happen...
petersen114 and kgombe like this.
1/8 IC Fan is offline
Old 06-08-2021 | 10:47 AM
  #10937
savage24x's Avatar
When my browser redirects to novarossi.it, I replace the "it" with "com" and the website loads perfectly.
savage24x is offline
Old 06-08-2021 | 11:33 AM
  #10938
kgombe's Avatar
yes after doing that it worked...
kgombe is offline
Old 06-08-2021 | 11:35 AM
  #10939
R/C Nitro Engines and accessories for on road / off road car, air plane, helicopter and boat models - NOVAROSSI WORLD
Tigergutt is offline
Old 06-08-2021 | 02:54 PM
  #10940
timjs's Avatar
So then what does that mean?
timjs is offline
Old 06-08-2021 | 03:02 PM
  #10941
kgombe's Avatar
It means that they didn't pay to renew the domain in Italy..
savage24x likes this.
kgombe is offline
Old 06-08-2021 | 03:03 PM
  #10942
captain america's Avatar
Not much, the page hasn't been updated since December 2019.
illmatic94 likes this.
captain america is offline
Old 06-13-2021 | 07:56 AM
  #10943
Anyone else notice the factory needle settings for the truggy 28-8 makes the engine run lean? HSN set to factory gets the temps up and over 300F. Engine sounds fine, but I'm richening it since I'm not comfortable with those temps. I'm in eastern NC with always high humidity, and right now temps around the 80-100F range.
InTheZoneAC is offline
Old 06-13-2021 | 09:04 AM
  #10944
which carb do you have? There are 3 different lsn settings. I’ve found my 28-8 was pig rich. Maybe you’ve got an air leak?
ray4624 is offline
Old 06-15-2021 | 10:42 AM
  #10945
Tim W.'s Avatar
I'm too lazy to dig through this thread to find the answer but what glow plugs should we use in our novas now? OS, Protek?
Tim W. is offline
Old 06-15-2021 | 08:12 PM
  #10946
illmatic94's Avatar
pretty sure my os plugs work fine in my .12s
illmatic94 is offline
Old 06-15-2021 | 11:17 PM
  #10947
fyrstormer's Avatar
So don't use the "factory settings". Factory settings only exist as a starting point that should probably get the engine to start running, but they are by no means guaranteed to make the engine run properly. Except, of course, for that one guy who insists the factory settings have always worked perfectly for him and he's never needed to touch the carburetor -- there's one guy like that in every conversation about carb tuning.
fyrstormer is offline
Old 06-16-2021 | 07:25 AM
  #10948
I posted a video in this thread not long ago from RWmods in which he discusses this very issue. os plugs can be used but iirc he suggests adding a shim to compensate for the difference in the threads between os and nova plugs
cornonthecob is offline
Old 07-12-2021 | 03:13 AM
  #10949
well i had my second nitro race outing this weekend.
The old but newish 28-8 coupled with the JP-4 did much better on fuel then the 9886/41021 combo
I found that i may have had an air leak somewhere as i was able to get a much nicer tune after replacing all the fuel line.
The losi line i used to replace the dubro colored line seems to have a larger ID and idk if that makes a difference.
Overall though the day was cut short due to an intermittent switch failure but the truck was running fast and came off at about 240deg.
thanks for all the help rc tech haha
Galatians2 20 likes this.
ray4624 is offline
Old 07-12-2021 | 07:10 PM
  #10950
thanks for all the help rc tech haha[/QUOTE]
Glad your Novarossi is doing well for you. I haven’t posted enough to post links. Try one shot kill switch. I had constant switch problems until this one. It acts like a plug
Badboy3.0 is offline
