Like Tree352Likes
NOVAROSSI Engine thread....
Old 07-01-2015 | 12:41 PM
  #7936
Originally Posted by cczjordan
I have rb2097 pipe with a extra short manifold, will it be a good combo for 4btta?
It will work great, but you would probably want a longer type manifold for tracks with bigger jumps.
Eivind E is offline
Old 07-01-2015 | 08:57 PM
  #7937
cczjordan's Avatar
How is the top end of this pipe, i find 9901 lack top end combo with btta
cczjordan is offline
Old 07-02-2015 | 06:15 AM
  #7938
What is the best break in procedure for a P5XLT and what % nitro should be used?
MikeTinCT is offline
Old 07-02-2015 | 07:50 AM
  #7939
cczjordan's Avatar
Fuel that u will use after break in. 25%@30%, but i recommend higher lube %, byron speed blend with 11% lube
Old 07-02-2015 | 11:57 AM
  #7940
Searched a bunch and cant seem to find the answer Im looking for. Whats my best bet for pipe/header on a TNS Legend .25? I have a dynamite 086 I was going to run but not sure thats my best option. Its going in a Kyosho ST RR Evo. Thanks for the help.
gablett is offline
Old 07-02-2015 | 01:04 PM
  #7941
Hoese37's Avatar
There is a great break-in thread at the top of this forum.
Hoese37 is offline
Old 07-02-2015 | 01:11 PM
  #7942
joey91473's Avatar
I am sure if you PM Maximo (Neal) He can help you out with his motors.
joey91473 is offline
Old 07-03-2015 | 12:07 AM
  #7943
sn47som1's Avatar
2096 is a great all around power pipe thats smooth and has good mileage I hear. Pair that with a 41021. For even more RPM you can go 9886. Hopefully others chime in for some more suggestions as I know this is for truggy
sn47som1 is offline
Old 07-03-2015 | 12:09 AM
  #7944
sn47som1's Avatar
deleted
sn47som1 is offline
Old 07-03-2015 | 12:10 AM
  #7945
sn47som1's Avatar
sn47som1 is offline
Old 07-03-2015 | 04:55 AM
  #7946
Maximo's Avatar
9853/41001 will give the best power and RPM.... 2096/41021 will neuter the engines power, probably one of the poorest performing combos you could choose for a .25..........IMO stay far and clear from a 2096/41021 combo on the .25 unless you want it to run more like a .21 then a .25
Maximo is offline
Old 07-03-2015 | 08:14 AM
  #7947
houston's Avatar
So ,i got some of the new c5tgn plugs coming , supposed to be "the only plug for all occasions" according to novarossi . We shall see ,hope they are as good as advertised
For now im still using c6tgc after break in , cold weather c5tgc
Happy motorin'
And for the record 9853 with 41001 ,41019,41005 is a badass combo ,been using it on truck for a few years, glad youve seen the light Neal ,lol
2096/41021 is still an awesome power delivery for buggy though
houston is offline
Old 07-03-2015 | 08:28 AM
  #7948
beidle99's Avatar
Happy motorin'
Let me know when those plugs come in. I want to try them out as the c6tgc has been my all occasion plug.
beidle99 is offline
Old 07-03-2015 | 10:05 AM
  #7949
cczjordan's Avatar
What other pipe recommended to use with 4btt engine? Fuel economy n powerful then 9901/2096.
Old 07-03-2015 | 11:41 AM
  #7950
beidle99's Avatar
The 2058 pipe is a good inbetween for the 9901/2096.
Bottom end similar to 9901, top similar to 2096. But not as much on gas milage
beidle99 is offline
