Like Tree352Likes
NOVAROSSI Engine thread....
Old 05-15-2016 | 12:06 PM
  #8956
Schmidt368's Avatar
Originally Posted by bash bros
I've always preferred the c6tgc over the OD plugs, but out of the OD plugs I think the 277t is the best. The 288t is good too, but it's a little cooler and probably closer to a c7tgc. I don't think they make the 99 anymore, I could be wrong but amain doesn't carry it anymore I believe the v2 plugs are the only ones OD is making these days.
Thank you. I'll give the c6tgc and 277t a try.
Schmidt368 is offline
Old 05-16-2016 | 08:14 AM
  #8957
The Elite 5 is different from the M5. The M5 is more like a p5xlt with a tuned crank.
I found a store in Portugal selling Ultimate M5 with steel bearings, for 200 € and with the bearings in ceramic € 250.
I think for 50 € is not worth it ... for that price also buy a Werks B6 standard here in Portugal.
PJ
Pedro Jesus is offline
Old 05-20-2016 | 12:21 AM
  #8958
offroad dude's Avatar
Is there any difference between the Legend 4/ Mito 4 and the Legend 7/ Mito 7???
offroad dude is offline
Old 05-20-2016 | 10:36 AM
  #8959
Yes
Mito4
http://www.novarossi.it/2012/index.p...-off-road.html
Legend4
PJ
Old 05-20-2016 | 09:45 PM
  #8960
I was talking about on track characteristics. For instance, does one produce more torque than the other. I see that both have the same RPM's and the Legend is around $30 cheaper than the Mito.
Old 05-21-2016 | 02:29 AM
  #8961
Sorry but this can not explain it now who knows more about the Novarossi engines and is within the subject.
In my opinion the Legend 4 is a good choice.
PJ
Old 05-21-2016 | 02:31 AM
  #8962
Hi. I have a Clio and i would like to no how they compare to a Mito 4 and how the mito 4 and 7 are different on the track. Thanks
bretto107 is offline
Old 05-22-2016 | 08:40 PM
  #8963
II have no experience with the mito line of engines. I do have experience with the purple head line of similar engines. The 7 port Nova engines consume more fuel and have more bottom end power. A 4 port engine is smoother/more mid range to high speed, and much better on fuel.
Some people would consider the 4 port a buggy engine and the 7 port a truggy engine. Personnally I really like the 4 port in both. When paired with a pipe with midrange power bias, having enough power is not usually a problem.
Tannhellyea is offline
Old 05-23-2016 | 04:27 AM
  #8964
Ok. Thanks for the info.
Old 05-23-2016 | 01:52 PM
  #8965
Default glow plugs
So what's the deal with the c5tgn plug? It says that it is for all conditions, wondering if it is an better than a c6tgc.
TLR 8 4.0 is offline
Old 05-23-2016 | 03:31 PM
  #8966
bash bros's Avatar
Yeah c5tgn is for all conditions. But then again the c6tgc works for just about everything too, even in hot weather.
bash bros is offline
Old 05-24-2016 | 07:12 AM
  #8967
Just bought a Bonito 21-7xlb/a. Ran a used Nova for my last motor and loved it considering it was pinched 3 times. The only downfall was that my tank only lasted about 7.5 minutes. I assumed it would make it atleast 8 and ran out leading the amain.
So my question is... how do I get this thing to run top notch with good run times? Do I send it to someone (seems like that's what the fast guys do)? Sell it and get a different motor? Or what?
18ight7 is offline
Old 05-24-2016 | 04:23 PM
  #8968
HaulinBass's Avatar
what is suggested for pipe on a keep off 21-5 7xls in a truggy. i was thinking 9901 with a 41005 header but also have a 41021 i can swap on if its too punchy
HaulinBass is offline
Old 05-24-2016 | 06:30 PM
  #8969
Nova Rossi 9853 w/41021
Chris Reilly is offline
Old 05-24-2016 | 07:58 PM
  #8970
Jerm13's Avatar
Not a bad pipe to have...But like Chris said the 9853 or even the 9886. Both are awesome pipes and suit the trucks really well. Use the 41021 header for good all around performance, but if you feel the need for more low end, the longer 41020 helps. More mid to top end use the 41001.
Jerm13 is offline
