Like Tree352Likes
NOVAROSSI Engine thread....
Old 03-26-2016 | 11:36 AM
  #8866
bash bros's Avatar
Yeah elastic bands work just fine.
They've saved me a couple runaways when I had rx problems.
bash bros is offline
Old 03-26-2016 | 12:11 PM
  #8867
Originally Posted by houston
Btw those metal return springs will wear your carb slide boot until there is a hole ,guaranteed
Shrink tube at the end of the spring will cure that.
NitroVein is offline
Old 03-26-2016 | 12:17 PM
  #8868
HaulinBass's Avatar
or using a button head screw instead of a set screw to hold the ball end on and run the spring on the backside of the carb. the spring is always straight this way, and a straight spring ensures a smooth pull.
edit looking at my carb now i cant remember how i used to do that.
HaulinBass is offline
Old 03-26-2016 | 01:23 PM
  #8869
That, and mounting the spring in a hole on the cooling head. (I'm using a regular pulling spring)
That's the way I do it, and I have yet to have a carb boot wear through.
Old 03-26-2016 | 07:40 PM
  #8870
houston's Avatar
Ok let me "rephrase"
that spring when installed to recommendations will rub through the carb boot
dam
houston is offline
Old 03-26-2016 | 08:35 PM
  #8871
Hair band is so much easier and is cheap.
Chris Reilly is offline
Old 03-27-2016 | 03:35 AM
  #8872
dam
Agreed!
I wasn't trying to lecture you, just give friendly advice.
Old 03-27-2016 | 07:36 PM
  #8873
Default Nova clutch
Can anyone tell me if the new clutch and bell will work on a Losi buggy?
smash8ight is offline
Old 03-28-2016 | 05:43 AM
  #8874
Jerm13's Avatar
Yes... Pretty much any clutch will work correctly if you set it up right.... i.e. motor mount, collet, shims and so forth.
Jerm13 is offline
Old 03-28-2016 | 08:45 PM
  #8875
Hey what you guys take on the Adam Drake speacial 5off? New Novarossi motor wonder how different it is compared to a P5 , any pipe ideas?
Ofna2005 is offline
Old 03-29-2016 | 01:28 PM
  #8876
Jerm13's Avatar
Its a P5 "Clio" with a Mito/VirTus crank (14.5mm instead of the P5's 14mm) and 2 needle carb instead of the 3 needle and all blacked out! Lots of torque and will rev to about 40K RPM.
Pipe choice will depend on track size and what you need the motor to do, but I have been running an 53 and an 86 on my P5 with awesome results. Maybe a 2096 for a smoother power delivery.
Jerm13 is offline
Old 03-29-2016 | 02:27 PM
  #8877
Roelof's Avatar
Originally Posted by Jerm13
Its a P5 "Clio" with a Mito/VirTus crank (14.5mm instead of the P5's 14mm).
Because the Drake engine has a centered carburator it will not have a Mito/Virtus crank.
Roelof is offline
Old 03-29-2016 | 04:01 PM
  #8878
Jerm13's Avatar
OK.... so its a 14.5mm crank rather than a 14mmOr could be from the Bonito, which is also a 14.5mm....
Should have specified "SIZE!"
Jerm13 is offline
Old 03-30-2016 | 04:38 AM
  #8879
fizzy's Avatar
Anyone know why the racer10 code is not working on the novarossidirect website?
fizzy is offline
Old 03-30-2016 | 04:56 AM
  #8880
I know it doesn't work for stuff already on sale..
Herrsavage is offline
