Like Tree352Likes
NOVAROSSI Engine thread....
Old 11-08-2012 | 10:24 AM
  #4486
jboquire's Avatar
Default 21-4C wrist pin clip replacement
How often are the two little circlips should be replaced?, I racer at my local track told me they should be replaced every 3 gals, is this a true statement?.
Also, are these supposed to be installed in a specific position?
Thanks in advance, jb
jboquire is offline
Old 11-08-2012 | 09:47 PM
  #4487
merdith6's Avatar
Default Umm
I think you mean the c clips that install inside the piston. No need to replace them unless you remove them to change a rod or something. Otherwise they last forever.
merdith6 is offline
Old 11-09-2012 | 02:43 AM
  #4488
+1, replace
the clips if you replace the rod
menzo is offline
Old 11-09-2012 | 08:36 AM
  #4489
jboquire's Avatar
Thanks guys.
jb
jboquire is offline
Old 11-09-2012 | 10:11 AM
  #4490
revo61's Avatar
Has anyone used this fuel filter?
revo61 is offline
Old 11-11-2012 | 04:40 AM
  #4491
blade954's Avatar
New Novarossi web page looks good
blade954 is offline
Old 11-12-2012 | 11:29 AM
  #4492
Where can I buy the 6mm white venturi?
Drip is offline
Old 11-12-2012 | 11:46 AM
  #4493
Lille-bror's Avatar
Right here :-)
Lille-bror is offline
Old 11-12-2012 | 01:07 PM
  #4494
Thankyou
Drip is offline
Old 11-18-2012 | 08:50 AM
  #4495
My carb is stuck, it won't budge. How would I remove it?
fung_kyle is offline
Old 11-18-2012 | 10:25 AM
  #4496
Sounds like your clamps are still stuck in there?
Unscrew the screw a little. Tap the screw with the screwdriver, to pop out the one clamp. Then use something practical, like a screwdriver, to tap on the other clamp, and pop that out. After that your carb will come out.
Next time don't tighten so hard
Eivind E is offline
Old 11-18-2012 | 10:46 AM
  #4497
air8's Avatar
Many times they are THAT tight from the factory. I've opened brand new engines, removed the carb clamp, and screw completely...and still had to use full size pliers to twist the carb to free it up.
Not like that everytime, but many times.
air8 is offline
Old 11-18-2012 | 10:47 AM
  #4498
Maximo's Avatar
I have not had a Nova ike that...but have seen some other brads exactly like that...nasty tight in the block..amazing the factory would even have assembled them that way
Maximo is offline
Old 11-18-2012 | 02:11 PM
  #4499
Originally Posted by houston
first off this should be discussed in a clutch forum but
did you use a new clutch bell?
did you scuff the clutch bell before installing ?
did you clean the grease out of the bearings ?
did you break in the clutch by giving it copious amounts of throttle then putting a load on it by forcing it to the ground ?
is your flywheel nut tight and not slipping?
go through that checklist then get back to me
hope this helps
Monty, what do you use to scuff the clutch bell? Thx
redliner140 is offline
Old 11-18-2012 | 04:20 PM
  #4500
houston's Avatar
Scotch brite pads work great
I'll usually buy the stuff at the hardware store, you can purchase all different abrasive grades, but scotch brite will work great
houston is offline
