Like Tree352Likes
NOVAROSSI Engine thread....
Old 11-02-2012 | 09:03 AM
  #4456
Originally Posted by houston
Thats up to you Elvind
It will still run good , u just wont quite get the long useable span from it
Ok cool, what is the "terminal" measurement where it's absolutely done for?
Eivind E is offline
Old 11-02-2012 | 10:54 AM
  #4457
houston's Avatar
I usually judge it by the amount of play/slop the rod-crankpin fit has in the tdc part of tge stroke with rod and crank out of engine , if you can feel a fair amount of slop thats no bueno , it will just hammer out a new rod , usually compeletely unuseable at 4.88mm imo
Fyi: i will only re-rod at 4.92mm or larger at smallest measurement
Tip: watch for coning of the crankpin and ovaling (out of round)
houston is offline
Old 11-02-2012 | 11:05 AM
  #4458
I figure this engine has probably seen better days then..but I've got two more 21-4C, so we'll survive
I was just hoping I could get more mileage out of this, for the hell of it really, no real good reason. It does seem round though it is only measuring too small.
Other question, for your expert judgement: with the flywheel on, if you can move the crank in and out (not up and down, but in and out) does this mean the bearings are shot? Seems to move quite a lot, difficult to tell just by eyeballing it but it's quite a bit.
Eivind E is offline
Old 11-02-2012 | 11:19 AM
  #4459
houston's Avatar
If you pull the crank out while pushing the collet tight up against the front bearing , then install flywheel and tighten flywheel nut it should get tight no matter , if front bearing races/balls are worn it will most likely leak out the front bearing.
houston is offline
Old 11-02-2012 | 11:20 AM
  #4460
With the flywheel nut securely tightened, it will move in and out. And when I took the flywheel off, I noticed it seemed like the inner metal bit of the front bearing would move in and out with it.
Eivind E is offline
Old 11-02-2012 | 11:57 AM
  #4461
houston's Avatar
gotta make sure your collet is tight up against the bearing before installing the flywheel Elvind
houston is offline
Old 11-02-2012 | 11:58 AM
  #4462
Maximo's Avatar
a bearing that is too loose can do that...... no matter how you tighten th3 flywheel it will walk in and out
Maximo is offline
Old 11-02-2012 | 12:06 PM
  #4463
houston's Avatar
so youre saying that when you pull the crank out to push the rear bearing forward then push the collet in so it pushes the front bearing towards the rear bearing and tighten it all down it will still move?
(this is not an argument)
novarossi rocks!!
houston is offline
Old 11-02-2012 | 12:31 PM
  #4464
hambone's Avatar
[QUOTE=houston;11396966]so youre saying that when you pull the crank out to push the rear bearing forward then push the collet in so it pushes the front bearing towards the rear bearing and tighten it all down it will still move?
novarossi
hambone is offline
Old 11-02-2012 | 12:33 PM
  #4465
hambone's Avatar
novarossi rocks!!
My FMS did that exact thing. It had 6.3 bearing and with collet tight against front bearing it moved in and out.
hambone is offline
Old 11-02-2012 | 12:45 PM
  #4466
Well I tried just sliding a new rod on the crank and sort of jiggling it about, it does seem a bit loose in there.. might not serve any purpouse to use that further then?
Yeah, even without the flywheel on if I pull the crankshaft in and out, I can visually see the inner tubular metal part of the bearing moving in and out. Does this mean the bearing is done for?
I have another 21-4C engine which also has this but much less of it, so I was thinking that might be the start of it?
Eivind E is offline
Old 11-02-2012 | 01:34 PM
  #4467
I would say your front bearing needs replaced by what you are saying. The crankshaft barrel (induction window portion ) should but right up to the backside of the front bearing inner race. Provinding case has proper depth in crank bore between bearings, this thrust movement of crank should be minimal. Front bearing is usually the one that dictates endplay due to design. If barrel of crankshaft is longer than the crank bore in case, this endplay will be more pronounced due to one small radial bearing now trying to also control thrust of crankshaft aggravating the wear rate of the front bearing. Also not good on the connecting rod when crank is walking in and out with the varried loads these engines experience at full song.
JLinney is offline
Old 11-02-2012 | 02:28 PM
  #4468
Guillermito's Avatar
Hello, for the Nova Plus 4 which is the best pipe, 9901 or 2096? another pipe would you recommend?
Thanks. Best Regards.
Guillermito is offline
Old 11-02-2012 | 02:41 PM
  #4469
houston's Avatar
U cant go wrong with either
houston is offline
Old 11-02-2012 | 02:46 PM
  #4470
SEF's Avatar
SEF
Either.
9901 for a tad bit more fuel mileage with a little less grunt.
Another popular choice is the 9853 for more bottom with a little less mileage.
2096 for a combination of good mileage and bottom.
SEF is offline
